Question about Radio Communications
Over modulation in mic gain when Xmiting on Ic-M700 pro SSB radio
When transmitting the modulation is distorted when the mic is close to mouth but is understandable when held about 12 inches from the mouth.This is reportd by another boater about 15 miles away at frequency 2.802 mz and 4.146 mz.
SOURCE: No AM carrier or modulation. SSB transmits good
Great now check TR42 AM POWER then check TR41 AM POWER REG. They are on right side twards rear of board with front of radio faceing you part side up. A good place to start!
Posted on Jul 07, 2007
Shuttle83
  • 1139 Answers
SOURCE: president mckinly ssb/am model with mb8719 pll chip.
It looks like you had some loose connections in that CB. you may want to also check for other cold solder joints throughout the units and touch them up with some solder. Might I suggest you use a desoldering tool and then just add new solder to the connection.
Posted on Sep 05, 2007
Communicomm
  • 90 Answers
SOURCE: Cobra 200gtl High Power Transmit problem??
Depending on the type of power supply, radio frequency (RF) energy from the transmitter may be 'fooling" it into thinking that you're overloading it. Check to see if there's any discernible dimming of the meter lamp when this problem occurs, if so, the supply is the culprit.
Otherwise, its probable that the final amplifier transistors are overheating, either they are 'leaky' or not properly attached to the heat sink.
Posted on Sep 26, 2008
  • 17 Answers
SOURCE: pro 640e
How are you testing the audio out?
Are you using another radio?
If so, are you REALLY sure the other radio is ok?
If the other radio is ok, how do you know the mic is ok? have you tested it with another radio?
If the mic is ok, id have a look at the mic socket to check that all the pins are still there. Then open the radio up and check the socket is still connected to the main board.
Let me know how you get on..
M3ODQ
Posted on Feb 02, 2009
  • 219 Answers
SOURCE: uniden grant ssb cb, receives but no transmit,
test your voltage regulator and make sure you don't have a bad crystal
Posted on Dec 16, 2009
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Apr 29, 2016 | Yaesu FT-857D transceiver
Why no modulation in transmit mode?
Without seeing it I would guess (and it's only a guess) that maybe you have a broken microphone wire. If it's a factory mic the most common place for it to break is right up from the mic plug. Factory cords are not flexible, their really stiff. We could really use some more information. Mike
Oct 15, 2015 | Uniden Radio Communications
Why is there no transmit modulation?
'mic gain' adjusted for optimum amount of modulation?
Oct 15, 2015 | Radio Communications
Distortion
turn the mic gain down, you need a meter or sprectrum analyzer to see what you're doing
Apr 17, 2014 | Yaesu FT-920, 990, 1000, 2000, FTdx-5000,...
Ic-735 distorted modulation-audio
bad mic wiring, overdriving the mic, mic gain set too high, compression level set too high
Sep 19, 2013 | Icom Murata CFM455K D Filter for IC-735
Galaxy dx 959not getting out far
MAKE SURE ALL CONTROLS ARE SET RIGHT MODULATION FULLY TO RIGHT CLOCKWISE, R-F GAIN FULLY RIGHT CLOCKWISE. TRY TO GET YOUR MATCH A LITTLE BETTER
Feb 23, 2013 | Galaxy Radios DX 959 SSB CB Radio
FT-890AT yaesu transceiver has distorted transmit audio
Hi Ronald,
Could the problem be related by having the mike to close to your mouth? This is the most common cause of over-modulation/ distortion from the transmission end.
If you have the mike 3-6 inches from the mouth and speak in an even non loud tone, that would help sort that out. If this is not the source of the over modulation/distortion, then you may have a transmitter issue, which would require the unit to be serviced by a qualified radio technician or ham radio operator, if you know one willing to look at it for you.
I hope that this has helped you.
Cheers,
Peter
Dec 01, 2012 | Radio Communications
Powers up ,receives,but no transmit
This is never a good sign. This is usually a sign of a bad final.
If the radio doesn't transmit in SSB or AM, then it either means, Both finals are bad, (which is rare) or there is another problem causing the problem.
If it transmits in SSB, but not AM, then the AM final is blown and needs to be replaced. Its a job for a tech.
If both SSB and Am are not working it needs troubleshooting by a tech.
If you feel ambitious, you can pull the bottem cover off being careful of the speaker wires and make sure the TX section is connected.
Inside the radio, there will be one wire with a plug that is hooked to a pin near the center of the radio. And an empty pin. The empty pin is the test pin, ignore it. Make sure the plug is on the pin all the way, and not loose. If its on good, then it needs further troubleshooting.
Other things you can check:
Make sure the mic works.
Make sure the mic gain is up.
Aug 24, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Pro 640e
M3ODQ
Feb 02, 2009 | Radio Communications
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
