Question about Hoover Vacuums
Hoover steam vac making loud noise, not running
Was working just fine, changed outlets and now makes loud noise and doesn't work
reddevil6
  • 1673 Answers
SOURCE: Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Posted on Jan 16, 2008
micromaster
  • 3614 Answers
SOURCE: lost instructions for hoover steam vac
kindly please wait...
Posted on Jul 13, 2008
SOURCE: brushes won't spin on hoover steam vac ls
I have the SteamVac Dual and there's a screen on the underside of the unit. It's beneath the brushes and it's red. You have to pull and wiggle it to get it out. With the machine unplugged, lay the unit with the handle on the floor. In the owner's manual ( http://www.hoover.com/pdfs/manuals/F7222900.pdf ) this is shown on page 10 figure 3-2. Clean that screen.
If they still won't spin, then take the brushes out. Again, with the unit on the floor, you simply grab the unit firmly and pull towards you. It's much easier to remove than the screen. I took the brush unit outside and blasted it with the house. You'll have to pull out whatever fur balls are clogging it but eventually you'll see that the brushes spin freely with the water squirting on them. Plug the brush unit back in and - in my case - they started spinning.
Posted on Aug 02, 2008
  • 691 Answers
SOURCE: My Hoover steam vac dual v's brushes will not spin
sometime when the brush is not turning their are less resistance to the motor, so it will turn allot faster than normal. The turbine gear assembly which connected to the brush assembly probably broken, all the gears are made out plastic and they can easily break,strip or worned over period of usage. the assembly cost around 20 bucks and it not that hard to replace and it not that hard to take it apart, just remember what goes where. I wonldn't surprise when taking the vacuum apart as you observed closely and inspect the brush unit and the turbine gear assembly you might easily spot what broken and need replacing. hope that help some; and if you don't want to fiddle with it, your local vacuum repair guy can probably do it for less than 40 bucks. you can go on-line vacuum parts.com
Posted on Oct 04, 2009
  • 389 Answers
SOURCE: My Old Henry hoover is making a VERY loud noise
Most likely the motor bearings have worn out. You can fit a new motor quite easily, but if you need to pay someone else to do it for you the labour plus motor cost will probably make the job uneconomical. Sorry to be the bearer of bad news...
Posted on Feb 19, 2010
I have a model f7411900 steam vac from Hoover and it started making a loud noise like a broken belt does in a vacuum. Does this have a replacement bely
Open the product, make sure first that it is not something stuck inside. If it is a belt, check with amazon. Just make sure that you have the correct model.
Aug 24, 2016 | Hoover F7411900 Maxextract Dual V Carpet...
Hoover steam vac spin vac making loud noise sparks flying
The only source for electrical sparks is the motor so it must be checked. Bad motor brushes or a broken wire are possible causes. Do not use in this condition.
Aug 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
How do we get at the drive belt? The cover seems to be sealed.
There is no belt in a Hoover SteamVac. The brushes are turned by an air driven turbine. If the brushes are not turning, it is usually because the turbine has seized up and may need replacement. Insert a screwdriver into the square hole that the pin on the brush assembly normally fits into and see if it turns. If it doesn't, you will need a new turbine.
Jun 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac..F7452-900. not working in wash-auto rinse mode
This problem sound like you hav a problem with the pump. I would take it to a shop for service
Sep 26, 2009 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover started to make loud noise
It sounds like a bad motor. Take it to a local vac shop and they should be able to order the motor for you.
Apr 13, 2009 | Vacuums
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac dual v makes humming noise and nothing else.
Is the overfill valve (the yellow thing) in the waste container stuck in the up/full position? Maybe it just needs to be rinses well to avoid it being stuck and shutting off the vacuum portion of the cleaner.
Oct 09, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
MY HOOVER Steamvac F5906-900 does not run
There is a switch, but could be a bad cord, or the motor went bad.
Jan 06, 2008 | Hoover F5906-900 Upright Steam Vacuum
Vacuums Logo
122 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
