Question about Coby TV-DVD1350 13" TV
My remote is dead. I want to program the TV from the buttons on the TV set. How can I do that?
I went to the buttons on the TV set and pushed TV Setup. Then I tried to get into Channel set up but when I reached that point, it didn't work. There are no arrows on the TV, so I can't do what the remote does.
    Top Expert:
  • Coby Master
  • 74,211 Answers
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Posted on Oct 25, 2012
How can I program my RCA universal remote to my element tv , what button to press for the light to blink and the code to put so it can work on my tv
RCA does not have for a code Element TV. With that being said there is a work around:
Turn on your TV.Then push the code search button until the LED still ,when the LED keeps on let go the button now push and release the TV button then push and release the power button until the TV goes off, when the TV turn off stop to push the off button now push the set button the code are already set on the remote control( you might have to push the off button almost 100 times or more until you get the right code for your TV. Best of Luck
Aug 26, 2015 | RCA Televison & Video
How do I program a tv code into my remote
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Jan 05, 2014 | GE Tv Vcr Sat/cbl Remote Vsqs1495...
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
Small vibe remote from dollar general doesn't have a set button that I can see. Does anyone know where its located?
i lost the book to vibe remote ...i just went and bought another remote returned remote kept book..here it goes....hold down device tv cd vcr button till light goes on while holding dont let go wait till light goes out then hold down power button while still holding both buttond now wait for light to go out then let go of both buttons then point remote at device and push power button untill device turns off then push stop button to set and there you go all set....note you may need to push power button a bunch of times to find code so hang in there...if in doubt start over
Sep 26, 2012 | Televison & Video
Need intructions how to program remote control on vip722k second receiver
Press and hold down the SETUP button located on the remote. Wait until the INDICATOR light turns on. It will blink once the button is pushed, however once you see the indicator light stay one, release the button. Click the button to the DEVICE you wish to program. If it is a TV, then click the TV button. If it is the cable box, then click CBL button. After doing so, the indicator should still stay on. Press the DOWN CHANNEL button several times until you see the RECEIVER yo wish to program respond. Example: If it is a TV, then you will notice the CHANNEL change once the remote locates the correct settings for that receiver. If you see the receiver respond and you are pushing the down channel button but nothing is working, it means you passed the internal settings of the remote to the receiver. Try pushing the CHANNEL UP button slowly. It may be able to relocate the the proper settings. Once you see the channel change again, press ENTER to program the remote. If this fails, retry the same steps. In some cases you may miss the correct internal settings.
Nov 23, 2010 | DISH Network IR Remote Control
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
Codes to program the RCA Universal remote control for a Magivox T.V.
My dear friend if your remote control got the code search button try with this.
Push and hold code search button until the led stand lit,now release him push and release the tv button the you need to push and release the power button until the tv set turns off push and release the button set and the code get in the memory of the remote.
You need to turn the tv manually.
Good luck
Sep 13, 2008 | Televison & Video
Panasonic TH-42px75u Audio went out
re program remote codes 018,016,007,049,067,074,076.
you have to take your remote settings to default
Sep 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Programming my remote.
I have the same dvd player & the remote went dead. I have been searching & finall found a web site that will help you. The short of it is I have a ATT 200 universal remote that my son gave me & I looked that up on remote.com & it has all kinds of Q&A to research, and I found out if I press my AUX button till all 4 modes flash twice, I can press HELP button & the next set of flashes are actually the code.It is called code scan. Not sure all remotes have this feature, but worth looking into. Hope you find your code. Happy New Year!!
Posted by; TMazzucchi
Aug 02, 2008 | Emerson EWD7003 DVD Player
RCA RCR 3273 universal remote
for codes:
http://www.rca.com/codefinder
Nov 27, 2007 | RCA Universal Remote 3 Device Remote...
Coby TV-DVD1350 13" TV Logo
64 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
