Montgomery ward 700 gas heating system,model DD60190A,series PVW75 wont ignite
The pilot light is on but it wont ignite..iv turned it on and off a few times(the power switch and thermostat switch) but the thing just wont kick on..its at my moms house and i dont know much about these boilers :/
hotuna
  • 288 Answers
SOURCE: Ward Heater Company M0021
These old units have a simple gas valve and a separate regulator. Your best bet may be to replace the gas valve to something more modern. Trouble shooting this most likely be a waste of time, as parts probably aren't available, other than the thermostat. by-pass it, (connect the 2 wires together) and see if it comes on. The blower shouldn't stop the burner to come on. Sounds like the gas company doesn't want to crawl under there to light it.
Posted on Dec 26, 2007
picatudo
  • 239 Answers
SOURCE: pilot light won't ignite, gas company came out, got gas
the glow plug or thermocopler is bad
Posted on Jan 03, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: goodman gds80703 turns on and off intermittendly 3 light blinks
There will be a diagnostic code that will blink on the control board. Look thru the clear window at the control board after the unit does not light up. On the reverse of the front panel, you will find a wiring diagram and in that area there will be a diagnostic code table. Sounds like a bad gas valve.
Posted on Feb 18, 2009
SOURCE: Ducted heating unit blows cold air and fan is always on..
that s correct the control is done by the thermostat stop the heating up to your set point and restart if the medium temp is under the set point
if this sequence fail means
- no power to the control element or is defective
thanks
Posted on Apr 27, 2009
SOURCE: Laars Lite 2 - Turns off after 5mins of being on!
This happened to me and the tech came out and change the pressure switch and it worked fine afterwards
Posted on Sep 09, 2009
Ward Floor Heater, Model 570 EDR, works but is outputting much less heat than normal. Any information about where to look, parts I might need, etc would be greatly appreciated.
"The valve stem labeled Hot at 12 oclock and Off at 3 oclock,"
Is probably the problem. I'd try wd-40 overnight to see if it would free up the valve. It worked on a similar problem outside gas grill valve.
Mar 04, 2015 | Montgomery Ward Heating & Cooling
Just need to know how to light the pilot on a Montgomery Ward wall furnace model sfb-50219
I can't speak to the specific model but with most pilot lights, there is a switch setting or button for lighting. If you release that switch or button too soon, the pilot will not remain light. Hold the switch or button ON while you light the pilot. Keep holding the switch or button for about a minute until the heat sensor is sufficiently warmed that the pilot light stays on. Good luck.
Nov 13, 2014 | Heating & Cooling
We are having difficulty lighting the pilot light on our wards gas wall heater. Is there a diagram that shows where we are suppose to put the lit match and which way to turn the knob? Thanks for your help
you may have to push down on gas knob to start gas flow for pilot move flame so it licks thermo couple detector.
if thermocouple gets too old it will not generated enough power to keep relay open for pilot
Nov 25, 2010 | Montgomery Ward (223600UP) Heater
Lawn Mower wont start
You need to obtain a manual for Briggs & Stratten engines. All the info you need will be in it. The most common cause for non starting in these engines is "Tight Tappets" Wether it's an OHV or the old "L" head engine, because they rev and work so hard, the valves seat themselves deeper into their seat which reduces the valve clearance. There is no adjustment on the older "L" engines, so you have to remove metal from either the valve stem, ot the lifter itself. I have in the past done this in situ with a point file, but it is a tedious job. Otherwise you must remove the head and take out the valves and grind the stems. A tricky task and probably should be done by a mechanic.
Apr 06, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
How do i light the pilot on a ward floor furnace madel 570 edr
You need a very kong wire and a kitchen match. Turn the knob on top to pilot and push down have your flame already down thru the pilot hole at the bottom of the inside of furnace. Hold for a few seconds and release knob trun to heat. This unit works on a power pile systm and generates milivolts from the flame. Rus
Dec 13, 2009 | Montgomery Ward (223600UP) Heater
Furnace wont turn on pilot light is on thermostate works
How do you know the thermostat works? Can you turn the fan setting to on and the fan comes on?
Have you had the door off lately (to light the pilot)? If so then make sure the door is back on correctly as the unit may not run if door is not on right.
Nov 21, 2009 | Montgomery Ward (223600UP) Heater
Heating & Cooling Logo
312 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
