Question about Kenmore Washing Machines
How do I bypass the lid switch for Kenmore Washer 11022852100?
There are 4 wires (blue, white, yellow, and red). All other solutions posted on previous questions mention two or three wires.
AlmostBob
  • 550 Answers
SOURCE: I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Posted on Oct 02, 2008
  • 333 Answers
SOURCE: How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
Posted on Nov 28, 2008
Maytag317
  • 1136 Answers
SOURCE: kenmore washer lid switch bypass failure.
HI. Check and see if you might have tripped the breaker. If there is a ground fault outlet close by. check that as well.
It sounds like you bypassed it properly. Try and reconnect the wires with the wire nut. Sometimes it doesn't connect properly.
I hope this helps you.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
  • 37 Answers
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Posted on Jun 20, 2009
  • 36 Answers
SOURCE: How to bypass a lid switch on a Kenmore 90 series washer?
bypassing the switch is done by connecting the two(outer 2)wires.thus closing the switch circut to the timer
Posted on Jul 25, 2009
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
My washer sensor turns on and then the lid light starts flashing and the washer will not turn on. What is wrong with it?
What is the model number listed on the unit?The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
Nov 18, 2012 | Maytag Centennial MTW5800TW Top Load...
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Kenmore Lid Switch Bypass Test
put a jumper wire from blue to pink
Jul 07, 2008 | Kenmore 20722
Washing Machines Logo
880 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
