Question about Hoover F5832-910 SteamVac Supreme Vacuum
Hoover f5825 manual
Gets power, but won't function beyond making noise
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
Customerservice
yes it does unscrew it will be tight and you will need alot of presure to unscrew try tapping it with a screwdriver handle turnig it the link below is the manual page 10 is filter change.
http://hoover.com/file/979/http://hoover.com/file/979/
Jul 26, 2013 | Hoover Vacuums
Hi. My dyson dc14 wand works great then all of a sudden if something too big or even just the carpet it makes a sucking noise & the purple round bit in the actual Hoover makes a funny noise & then...
Sounds like a blockage. I have a DC14 and I have never had this problem. You can easily remove the wand from the flexible hose and the flexible hose from the machine to check for a blockage. Don't allow paper or larger items to go into the machine, especially the wand, pick it up by hand first. Find the online manual here: http://www.analogstereo.com/dyson_vacuum_owners_manual.htm
May 03, 2013 | Vacuums
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Wand shutdown & won't come back on
My Hoover did that. Turned out to be that the motor shorted out.
May 11, 2012 | Vacuums
Is there a wrong way to attach the belt and the sweeper?? My Hoover Runabout is making a rubbing noise, like the sweeper is hitting something, and it's real hard to push.
take off the belt . clean any hair from brush roller make sure movement smooth . re position belt and move by hand to make sure roller is not skew , , rubber is riding sideways and causing friction .
Mar 22, 2012 | Hoover Vacuums
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
I NEED THE INSTRUCTIONS ON HOW THIS MACHINE IS TO OPERATE WHEN IT IS FILLED WITH THE SOLUTION.
Hi m-works. I would, too; but Hoover's website no longer makes manuals available for some models, including mine.You might luck out. Try Hoover.com/manuals and put in the mod no. & give 'em a try
Aug 09, 2011 | Hoover F5870-900 SteamVac Vacuum
Brushes won't turn
The brushes are powered by air suction from the motor. At the heart of this complicated system are roller bearings. When one fails the system fails. This is not one of the parts that Hoover thinks is needed on it's parts site so I've haven't found a way to repair this.
Jun 28, 2011 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover F5832-910 SteamVac Supreme Vacuum Logo
78 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
