Question about Apple iPhone Smartphone
I can use the calculator on my iphone but I cant use the keypad..
I cant use the keypad to dial a number but I can touch all the other buttons and use the calculator and all that stuff... Also, I cant hang up phone calls, I have to wait until the other party hangs up....
  • Anonymous Apr 20, 2009
    789 keys on keypad wont work
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 113 Answers
Try to reset your device once to factory setting. switch off your phone first than hold power and home button for 10 seconds.
Posted on Jan 02, 2009
I want to reprogram some numbers on AT&T 822 (21213)
1. Lift receiver, touch "program" (above number keypad, on the bottom left of programmed numbers).
2. Enter phone number (1-AC-Number).Touch button for quick dial station (e.g., Name of Person to Call).
3. Hang up phone.
4, Lift and touch programmed button to dial (new) number.
Oct 06, 2013 | Lucent AT&T Speakerphone 822 (21213)
Dial button
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Dec 02, 2012 | LG enV Touch VX11000 Cell Phone
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Problem in making a call
to restore to factory settings (clean boot):
turn off the phone or reset it and hold the enter button with the volume DOWN for about 2-3 secs.
after that follow the directions on the blue-white screen.
Sep 04, 2009 | HTC Touch Diamond Smartphone
My phone has been working but today it will not let me dial out any phone numbers on my keypad
Hold the power button and the menu button down until the phone reboots.
You should be good to go
Jun 01, 2009 | Apple iPhone Smartphone
Iphone keypad stopped working
I believe this problem persists after you have jailbreak
Your iphone . Now since you have done it the next step
Is to install a Ripdev application from the installer module. After
You have installed it successfully then you go to your iphone settings.
Here you will see Ripdev application installed then touch it to expand it more.Then here you will see Ripdev products, again you touch it
to expand and then you will notice a title which says Licenses
there you have to touch the Kate application and after that
you have to touch "purchase Authorization code" or for trail bases just touch the application which says “Ask for Trial License” after that
go to the iphone module that is the key pad and you will see
its working fine.
In short after jailbreaking and installing Rip Dev you have to purchase
That application to get your keypad working.
With this 100% your problem will be solved.
Apr 25, 2009 | Apple iPhone 3G
Group code
I believe what you want is at the bottom of this list.
If you frequently send faxes to the same group of telephone numbers, you can assign these numbers to a group.
Only Speed Dial and One Touch numbers can be assigned to a group. A maximum of 25 Group Numbers (WorkCentre Pro555) / 50 Group Numbers (WorkCentre Pro575) can be assigned (in the range 1-1999). Preset group numbers can also be used for polling.
The following information is included below:
  • Create a new group
  • Add numbers to an existing group
  • Delete numbers from an existing group
  • Delete an existing group
To print the Group Phonebook, see the Related Items below for additional information.
Create a new Group:
  1. From the Standby Mode, press the [Menu] (up arrow) button on the Control Panel, then press [3], [3].
  2. Use the numeric keypad to enter the Group Dial number (1-1999) you want to assign to this group.
  3. Press the [Enter] button. The screen will display a name.
  4. Use the numeric keypad to enter the Group Name (20 characters maximum), then press [Enter].
  5. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, then press [Enter].
    NOTE: The One Touch and Speed Dial numbers must already be programmed. See the Related Items below.
  6. Repeat step 5 to enter additional numbers.
  7. When you have entered each number you want to include in this group, press [Enter].
    NOTE: Group Transmissions are easier if a group is linked to a One Touch button.
  8. To assign this group to a One Touch button, press the One Touch button. To skip this step, press [Enter].
  9. Press the [Exit] or [Stop] button to return to the Standby Mode.
To add numbers to an existing Group:
  4. Press [2] to modify this group.
  5. Use the numeric keypad to enter a new group name, then press [Enter], or press [Enter] to retain the old name.
  6. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, and then press [Enter].
  7. Repeat step 6 to enter additional numbers.
  8. When you have entered each number you want to include in this group, press [Enter].
  9. Press the [Enter] button.
  10. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete numbers from an existing Group:
  6. Press the One Touch button you want to delete from this Group, or enter the Speed Dial number, and then press [Enter].
  7. Press [1] to delete this number.
  8. Press [Enter] to delete the number, or press the [Exit] or [Stop] button to exit without deleting number.
  9. Repeat steps 5 through 7 to delete additional numbers.
  10. When you have deleted each number from this group, press [Enter].
  11. Press [Enter].
  12. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete an existing Group:
  2. Use the numeric keypad to enter the number of the Group you want to delete, then press the [Enter] button.
  3. Press [1] to delete the group number.
  4. Press the [Exit] or [Stop] button to return to the Standby Mode.
elem_1_spacer.gif Related Items:> See AlsoHow To Print and Read the Group Phonebook Report
> See AlsoHow To Modify the Default Resolution and Contrast Settings
> See AlsoHow To Assign / Modify Speed Dials in the Phonebook
Dec 11, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Uniden Model EXP7900 How do I program button m1
One-Touch Dialing
Your phone is equipped with three .One-Touch Priority. keys for
instant dialing (m1, m2, and m3). You cannot store phone
numbers directly into m1, m2, andm3. They are only used
to dial phone numbers stored into memory locations 1, 2, and 3
on the keypad.
1. To instantly dial phone numbers stored in memory locations
1, 2, or 3, simply press m1, m2, or m3. (There is no need to
press talk, the phone will automatically dial.)
2. If no phone number was stored in memory locations 1, 2, or 3
on the keypad, pressing m1, m2, or m3 will do nothing.
I hope this helps.
Rollin CBs
Dean
Nov 04, 2008 | Uniden Cordless Phone
Cant dial out manually
If you happen to install Kate from cydia. Uninstall it! that causes the problem.
Sep 29, 2008 | Apple iPhone 3G
Fax not being sent
Somehow, a group dial # has been set. Here is how to delete it:
NOTE: Group Dial Numbers are entered using the One-Touch keypad on the left hand side of the WorkCentre. To change a Speed Dial that is within a Group Dial, the Group must be deleted first.
  1. Press the [Menu] button.
  2. On the left hand side of the Control Panel press the One-Touch [12] button.
  3. The LCD Display will read 'Select One-Touch for Group [01-20]'.
  4. Press the One-Touch key to be used for the Group Dial.
  5. One of two displays will appear:
    • If the Group Dial number has not been used:
      1. The LCD Display will read 'Group No: ### 1. YES 2. NO'.
      2. Using the Dialing Keypad press [1] to accept or
      3. Press [2] to return to step four.
      4. The LCD Display will read 'Enter One-Touch / Speed Dial> ##'.
      5. Continue with step 6.
    • If the Group Dial number has been used:
      1. The LCD Display will read 'Group ## Used 1: Renew 2: Other'.
      2. Using the Dialing Keypad press [1] to 'Renew'. This will cancel the Speed Dial or Group Dial entry and the Group Dial will be deleted.
      3. Press [2] to keep the current entry and select another Group Dial
      4. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
        Thanks, Joe
Apr 26, 2008 | Xerox WorkCentre 470CX InkJet Printer
Apple iPhone Smartphone Logo
181 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
