Question about Kodak 5500 ALL-IN-ONE PRINTER
Kodak 5500 All In One Printer set up problem
I just got a Kodak 5500 All in One Printer. When setting it up, I got an attention message, saying "paper jam" Clear jam and press OK to continue. There was no paper in the tray to jam. It would not turn off, I had to disconnect power. Then the printer head will not go back to center. It tries, but is like stuck. I called the Kodak support and after walking me through several things, he said they would send me a replacement, because the carriage is defected apparently and said for me to return this one in the box they send the replacement one in. However, I see like some styrofoam in the back and wondered if this was part of the packing, but he said no. So I am at a loss and very UPSET, I just unpacked it. Also the printer access door is very hard to close.
Any help or ideas would be appreciated.
Upset in South Ga
  • pollo101 Jan 02, 2009
    Thanks, but we already had reset the printerhead and reset the ink cartridges and they all clicked as they were supposed to but, it is difficult when the printer head will not locate to the center as it is supposed to do. And it still shows paper jam, and there is not any paper in the trays or anywhere in the printer.
  • 1,218 Answers
If you are getting a 'carriage jam' error as soon as you turn on your Kodak printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam: Open Door, clear carriage jam, and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck. Manually move the carriage toward the opposite side. Check the paper path and remove any piece of paper or any other object that is stuck in the path. Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t2952766-kodak_all_in_one_printer_paper_jam
Posted on Sep 28, 2010
  • 4 Answers
Remove the ink from the print head and FIRMLY press the printhead in until you feel and hear a click, replace inks. The foam should be removed, no tape or foam will be left after preparing for use.
Posted on Jan 02, 2009
Kodak 5500 aio will recieve faxes but won't send faxes
Make sure that the settings is properly set especially for the region settings. If problem persist please upgrade the firmware of your pinter.
Jan 07, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
My 5500 printer will not print from computer. never had this prob
Check your printer on the Control Panel, Printers and faxes and make sure that your printer is set as default printer and its Online. Then Unplug and re plug your printer.
Hope this would help.
Thanks
Josh - Kodak Specialist
Aug 13, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
My kodak 5500 all in one inkjet printer will send fax, but comes thru blank at the other end. Yes I have the document with lettering up like it says.
The problem, more than likely, is the quality of the scan. The 5500 sometimes overexposes the original. Test the scanner by scanning the document tou want to fax using HomeCenter software and looking at the screen preview. You can make some pre scan image density adjustments by changing the fax settings brightness setting to low (1 or 2) and changing the color setting.
Apr 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5500 Fax won't connect
Most likely problem is your phone company is blocking it for some reason.
Apr 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
How turn attention light off after replacing ink and cleaning printing heads
Press Menu to display the Main Menu.
2 Press �� until Reset All Settings is selected.
3 Press OK.
This is the reset for this device
Hope it helps
Regards
Ric.
Apr 13, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak5500aio printer will not print
You will need to replace it. There is almost no way around it.
Mar 28, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cannot install firmware
What version of Windows you have? or MAC? Make sure you are downloading the right firmware to your printer otherwise it will not install or even damage the printer!! I updated the firmware on my Kodak 5500 printer and had no problems. Try calling Kodak, 1-800-421-6699, they will be happy to help you.
Jun 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5500 ALL-IN-ONE PRINTER Logo
324 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
