Question about Sony Audio Players & Recorders
I NEED A RIBBON CONNECTOR FOR A SONY SYSTEM MODEL TC-W301,ST-JX301,TA-AX301
THIS AND OLDER SYSTEM
  • 1 more comment
  • ckbailey68
    ckbailey68 Apr 13, 2013
    I was trying to set up just the amop & the tapedeck from the TA-AX335 cmponents, but the ribbon power thing isn't working (the amp is on but the power isn't getting to the deck). Do all the components have to be hooked up in the chain for anything to work?ponents
  • ckbailey68
    Can you set up just a couple of the components of the TA-AX335 uintegrated system, or do they all have to be in a chain on the ribbon connector?
  • ckbailey68
    (*integrated)
    Genius:
  • 1,212 Answers
You should be able to get the length and conductor count from Digikey, as well as the Berg/Tyco type connectors. They may not match the originals, but they should work fine. Otherwise your best bet is Ebay.
Posted on Oct 31, 2012
  • 31 Answers
SOURCE: need to find wiring diagram for a sony TA-AX 295 home amplifyer/eq
Hi *****, Try these URL's good Luck. YUBEUT http://www.eserviceinfo.com/ www.hisierrahifi.com
Posted on Dec 11, 2007
groovy128
  • 5 Answers
SOURCE: Sony TA-AX301 Amp looses left speakers
many times this problem is the result of dust and or dirt that has collected in your control pots.ie.volume,balance etc....the solution is usually to take the amp apart to get to the pots and clean them out with tuners cleaner or some such product...a quick fix would be to rapidly move the knobs side to side or press the buttons or toggle the switches as fast as you can in hopes of clearing some of the particles from the affected area...
Posted on Feb 03, 2008
xalint1
  • 152 Answers
SOURCE: Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Posted on Jul 30, 2008
  • 57 Answers
SOURCE: Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Posted on Jul 06, 2009
SOURCE: I have a Sony Amplifier
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Posted on Jun 21, 2011
Tip
Older software PC not working in newer Operating Systems Windows
If you find that your older software is not working in your Win 8 for example. Right click the install icon for that program . A dropdown menu will appear. Then left click troubleshoot compatibility and run the program per instructions. If the program you are trying to install runs successfully then the settings are right. IF NOT, then select an older Operating system where it did work... e.g., Win 7, Vista, XP. You may have to also click Run as Admin if your system is set up that way. Look at the appended image.
on Jan 11, 2015 | Computers & Internet
I backed up with seagate portable drive system image 4th May.Would it have my older facebook on it?
Facebook settings and data are kept on the Facebook server, not your laptop. So, no, your backup will not contain your older Facebook info.
Jun 03, 2015 | Acer Aspire Computers & Internet
I have the trend Micro on the PC but the system Mechanic would not load to the PC I have had this PC checked by a professional and it should be free of any virus ect.
do you have an older version of this similar program on your computer? if you do have an older version, you would need to uninstall it first before install your newer system mechanic. trend micro may not be compatible with system mechanic. also what operating system are you using?
Apr 02, 2014 | Iolo Technologies System Mechanic...
How to reset the coolant sensor
There are 2 different procedures used to reset PCMs; depending on whether the vehicle has the older OBD1 emission control system; or whether it has the OBDII system. With the older OBD1 system; the PCM could be reset by disconnecting the battery for several minutes. But the later model OBDII system cannot be reset that way. It requires connecting an OBDII compatible code scanner to the vehicle, and using the scanner to reset the PCM. --------------------------------------------------------------------------------------
FGtech V53
Mar 21, 2013 | 1999 Buick Century
What is metric system?
Metric system is an easier to use and understand measuring system for all like distances and weights and volumes. 1 milimeter x 10 = 1 Centimeter 1 centimeter x 10 = 1 decimeter 1 decimeter = 1 meter 1000 meters = 1 kilometer (and 1.6 kilometer = 1 mile of the older system)
compare it to the older system 1 inch x 12 = 1 foot 3 feet = 1 yard 220 yards = 1 furlong 8 furlong = 1 mile (some sense of humour where you would go mad multiplying these numbers).
similarly in volumes and weights the metric is in terms of 10s while the older system was as maddening as the distances. But Americans still prefer the mile and pounds system. They are entitled to their humour or humor.
Jun 29, 2011 | Computers & Internet
Can the new 5 cd changer work with the older Bose
It will work as a manually-operated AUX input, but since there was no remote for the original system so that function won't be available.
Nov 29, 2009 | Bose Wave Music System CD Shelf System
Home Budget for Dummies
This is because you operating system is too new.. This software package was built for the older O.S. windows XP or older. To resolve the problem, you need to spend the 39.99 to get new software or only use it in an older computer that has the required O.S.
Jun 10, 2009 | Anuman Interactive Home Budgets for...
Voice keeps cutting out on navigator with latest updates
Try to uninstall the updates. May be that the new updates consumes more memory and also bandwidth. If ur job is done with the older one then don't use the newer version until u upgrade ur system (I think ur system is an older one with low memory).
Oct 11, 2008 | Computers & Internet
Computer Games on Vista
My friend has vista and she has said that a lot of stuff she could do on the older system/computer she can no longer do now! Have you tried?
Apr 24, 2008 | Computers & Internet
231 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
