Question about Dell 2155cdn All-In-One Laser Printer
Vertical Lines on Scans
Our office has a Dell2155cdn All-In-One Printer. It works great for everything. Except, a couple month ago, when you put a stack of papers in the top to scan a pink and blue line appeared on the scans. It has moved slightly, then was fine, but now we have a yellow line on the right side of the page. Other than that, the clarity, etc of the scans are fine, but we cannot use these scans with the lines for out of office use. I've cleaned both pieces of glass, so what else could it be? Should we call a repair tech?
  • Ayrann Oct 24, 2012
    The ONLY time we get lines is if we scan thru the top portion, when it automatically feeds the paper in.Scanning by placing the paper face down and closing the lid is fine, printing/faxing/copying results in NO line. I've already tried cleaning BOTH pieces of glass.
3 Suggested Answers
  • 3 Answers
SOURCE: Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Posted on Nov 20, 2008
sys_admin
  • 829 Answers
SOURCE: Black vertical line along left margin when using the adf to scan.
Check both the Fuser Unit and the Cartridge for lines . In any of the rollers are found with a line that means it needs to be replaced.
Posted on Jan 26, 2010
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Samsung HLR DLP TV with white lines from top to bottom. First had no picture, bulb is 10 months new, I replaced the color wheel, and just put in a used DLP Chip. Picture came back perfect, but these w
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 18, 2017 | Samsung Televison & Video
Ricoh SG 3110dn, SC 20200
you need change ink collector unit.
Sep 16, 2013 | Ricoh Office Equipment & Supplies
Canon MX860 prints crooked!
Does this happen when printing from the cassette (bottom tray), or the sheet feeder in the back, or both? Check that the paper guides are set snugly (touching but not buckling the paper) against the edges of the paper.
Apr 29, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Vertical colored lines in a scan
If the lines appear in the same location everytime, then it is from the scanner glass. Clean it thoroughly. No solvents except Isopropyl alcohol for cleaning.
S. Mohan, India
Mar 02, 2009 | Umax PowerLook III Flatbed Scanner
Replaced printer drum but still printing with vertical lines
Hi dermtex,
since the faint lines are vertical, I think there is some thing distored the laser beam, try clean the lenses of the laser unit by clean soft cloth.
hope this helpful for you,
thanks
Hamedo
Aug 18, 2008 | Brother HL-2070N Laser Printer
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Vertical lines
Get some freeze spray from radio shack then try placing a little spray on each chip on the video board and power supply board and each time you spray a chip look for the picture to clear up. When the lines go away you have located the bad IC.
Jul 09, 2007 | JVC HD-70G886 70" Rear Projection HDTV
Dell 2155cdn All-In-One Laser Printer Logo
441 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
