Question about Bosch Microwave Ovens
Plate will not turn on my Bosch innowave microwave
  • 8909 Answers
SOURCE: My Bosch innowave microwave oven
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Posted on Jan 23, 2011
  • 6771 Answers
SOURCE: Hi there, I have a
This indicates one of three things, there is a short in the magnetron, or high voltage diode , or the high voltage capacitor. Now! the other possible situation is the door switch has become defective and this would apply when you first plug in the microwave oven, either way it needs to be checked and depending on parts and labor the cost could come close to a replacement.
Posted on Feb 28, 2011
  • 77 Answers
SOURCE: MY 5 YEAR OLD BOSCH
Here`s a little fact about microwave`s, they are not healthy - http://rense.com/general70/microwaved.htm
We threw ours out, food taste much better cooked on the stove, oven or grill.
Posted on Apr 15, 2011
MicrowaveSvc
  • 9047 Answers
SOURCE: Need manuel for Bosch Innowave microwave, type
I would call the store from which you purchased it to get Bosch's contact info, or do a Web search using the term Bosch and the country it was made for or the full model number.
Be sure to look for the bosch domain name in the search results.
If you just blindly select a FixYa link, you'll likely be thrown back into this convoluted, polluted hell of a Web site.
Posted on Nov 23, 2011
  • 6771 Answers
SOURCE: Hi I have a BOSCH Innowave microwave only about 1.5 years old not sure of model number.... but the turntable has a massive chip out of it. Can I get the turntable replaced?
Yes! try Bosch online, they may provide a phone number or dealer close to your location, also! ebay is a great source for microwave parts, check out your local appliance repair man, and some TV repair shops.
Posted on Mar 19, 2012
My Bosch innowave has stopped rotating!
Check the voltage on the table motor. Basically if the wiring is intact, the problem will be the table motor. Not uncommon for them to fail.
Dec 07, 2014 | Bosch Microwave Ovens
Where do I find internal fuse in bosch innowave microwave
GO IN TOUCH WITH BOSCH OR THE STORE U GOT THE OVEN FROM..THEY WILL HELP U ...
Oct 17, 2013 | Bosch Microwave Ovens
My bosch innowave stops after like 30 seconds...power just cuts off and food doesnt get warm
Hi There,
Unplug your microwave for ten minutes, plug it back in, and test it on a cup of water. If the problem persists, you'll have to take it in for servicing or buy a new microwave. I don't recommend continuing use if it's turning off on it's own, that usually means a bad power supply and can result in curcuit damage.
Jun 06, 2012 | Bosch Microwave Ovens
Mar 19, 2012 | Bosch Microwave Ovens
Need manuel for Bosch Innowave microwave, type HMT9656EU/01
Oct 31, 2011 | Bosch HMT9656GB Microwave Oven
MY 5 YEAR OLD BOSCH INNOWAVE BUILT IN MICROWAVE HMT 8656 HAS JUST DIED. WHAT IS THE LATEST MICROWAVE TO REPLACE IT
Apr 15, 2011 | Bosch HMT8625GB Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
