Where can i get ribbon connectors for sony stero system part#26AWG THE END OF THE CONNECTED IS BROKEN OFF
THE RIBBON CONNECTER GOES TO ALL THREE
  • Audio Player... Master
  • 1,258 Answers
I doubt at this point you will ever find a new one but hope is not lost entirely. Since these are not high current cables the possibility exists to solder the one end of a ribbon cable to the board and then attach a dB connector to the cable for interconnection and taking the system apart. This would solve this problem. In fact ribbon cable of different types can be obtained new and this might be a good upgrade to do as most dB connectors are made with Gold flashed pins. The trouble is not many technicians will want to do this for cheap.
Posted on Oct 29, 2012
How do I remove and replace the keyboard on my satelite A 120 laptop. Can I have some instructions please.
Step one: Remove the two screws from the bottom of the computer that are holding down the Toshiba Satellite A100-S8111TD Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Toshiba Satellite A100-S8111TD Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Toshiba Laptop Keyboard.
Final step: To insert the new Toshiba Satellite A100-S8111TD Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Toshiba Satellite A100-S8111TD Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
G33k
May 09, 2011 | Toshiba Satellite A100-S8111TD Notebook
How the ribbons are run where the master and slave go. mine on startup it says unetected second slave
The motherboard will have two connectors for "ribbon" cables.
Each ribbon-cable has 3 connectors: one at each end, and one in the middle.
Thus, with two ribbon-cables, you can support up to 4 "parallel-ATA" devices (ZIP drive, LS-120 drive, disk-drive, CD/DVD drive).
Note that the 3.5" diskette-drive has its own ribbon-cable, and that ribbon-cable is not quite as wide as the other ribbon-cable.
How many devices do you have? Probably, one disk-drive, no ZIP drive, and one or two CD/DVD drives.
So, if you only have 3 devices, then the message is correct -- there is nothing connected to the SECOND ribbon-cable in the SLAVE position.
Tell your motherboard to "ignore" the secondary slave, if you have nothing connected at that position.
Jul 22, 2010 | Dell Computers & Internet
I had to remove a book of matches from my blue ray player on my ps3. all went well until i accidently pulled the ribbon cable from the motherboard and broke the connector for the cable. now i can not get...
you can have a new connecter implaced to do so take it to a good electronics repair person it should only cost you aproxx $ 20 for the part plus there labour
Jun 18, 2010 | Sony PlayStation 3 40GB System
I broken the plastic blue ray ribbon connector on my motherboard
unless you can find a great tech near you to repair the ribbon ( extrem hard to do but can be done ) call sony and order a new ribbon link cable
MY COMPUTER KEEP SHOW NEW HARDWARE NOT FOUND
you may have not properly set the jumpers on your new installed hard drive.
usually a computer will have 2 eide drive controllers where you would connect a ribbon cable. a ribbon cable has a middle connector and end connector and obviously another end connector that connects to the motherboard)
now you can connect upto to devices to that ribbon cable. most computers will have one device connected to the end connector (the hard drive) and no devices connected to the middle connector or sometimes they may have 2 device on the same cable: the hard drive on the end and a cd/dvd drive on the middle. others computers may have one ribbon cable for each device as computers usually come with 2 drive controllers (so you can connect 2 cables which means a total of upto 4 eide devices)
now, when you connect devices on 1 ribbon cable, the end device is the master device, the one the middle is the slave. to make a device a master or a slave you need to set a jumper. the jumper is usually located in between the ribbon cable connector and the power connector, the legend to know where the jumper goes to make it a slave or a master is usually on the label of the hard drive. you may need to check that label and with some pliers make the proper setting for that jumper.
on a new hd usually the jumper setting will be in master. so if you connected the hard drive on a ribbon cable that already has a master at the end it may not be detected. try to connect that master device on another ribbon cable that has no other devices connected and connect it on the end connector (not the middle one). if you have no other option but to connect it in the middle already having a master device at the end, set the jumper to on the slave position.
while you are at it. make sure you have your power connector and data (ribbon) cable properly seated.
if the caviar hd your are trying to install is an old hd and you know that you have the proper hd configuration and the cables properly seated, it is possible that no detection means hd failure.
Apr 04, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
How do i replace a sammsung R519 keyboard?
Step one: Remove the two screws from the bottom of the computer that are holding down the Samsung R519 Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Samsung R519 Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Samsung laptop keyboard.
Final step: To insert the new Samsung R519 Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Samsung R519 Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Apr 01, 2010 | Samsung NC10-14ROBL Notebook
How do I remove the keyboard from a Advent 7109B laptop, in particular the ribbon cable.
The ribbon cable is connected to the motherboard by either of these two methods.
The ribbon cable has a connector attached to the end of the cable and it fits into a socket on the motherboard.
OR
The ribbon cable just slots into a connector on the motherboard. To release the ribbon cable lift the locking bar up on the motherboard connector and the ribbon cable will be released and slip out easily.
To insert the cable back into the connector, lift the locking bar up, insert the ribbon cable into the connector as far as it can go and push the locking bar down to lock the ribbon cable onto the connector.
Mar 30, 2010 | Computers & Internet
How do you connect the ribbon connecter clip for the screen on tomtom go720
Had mine open just yesterday to see how difficult it would be to replace the battery, so I had the same experience reconnecting the ribbon. You first need to make sure that the little gray release tabs at either end of the connector are in the up position, then , where the ribbon is creased, you need to straighten it slightly. This will allow you to stand the screen up a bit straighter and make access to the connector easier. The end of the ribbon gets inserted on the top side of the little gray strip that you see running the width if the connector.with the ribbon inserted you then need to carefully push the little gray tabs back down into the locked position (flat with the top of the connector). Make sure the ribbon is straight and fully inserted, and don't forget to plug the speaker connector back in. try searching TomTom replacement battery on line and you should find excellent directions & photos on the entire procedure. Good luck.
Sep 23, 2009 | Tomtom GO 700 GPS Receiver
I am trying to replace an LCD on my Stylus 710. I
Are you a trained service technician with the service manual at your fingertips? If not, what made you think you could fix a sophisticated piece of electronics like a digital camera?
Aug 13, 2009 | Olympus Stylus 710 Digital Camera
Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
Apr 10, 2009 | Bose Acoustimass 16 System
27 people viewed this question
 Grubhead
Grubhead
