Question about HP Photosmart Plus B210A Multifunction Printer CN216AB1H
My catridges were low on ink, 2 of them I refilled and 2 I replaced, the ones I replaced were exactly the same as the ones before, HP ink cartridge 564 andit keeps saying incompatible ink cartridges a
I replaced 2 ink cartridges, black hp 564 setup and cyan hp 564 setup the EXACT same kind of cartridges that were in the printer before. An error comes up on my printer saying "Incompatible Ink Cartridge(s) Refer to status screen on your computer for details. Then it shows the triangle for the blue and the weird arrowhead shape for the black. Then it says Refer to status screen on your computer for details" again. There is no status screen on my computer. And these are the exact same kind of cartridges that were in before. I even tried putting the old ones back in and it still says "incompatible cartridge".
jonb3838
  • 237 Answers
SOURCE: black ink cartridge problem
is this a recycled or refilled ink?If so there is a known issue if not then check the connections and make sure there is no damage or is not bent
Posted on Apr 30, 2009
Crankstart
  • 696 Answers
SOURCE: How to refil HP 10 inkjet cartridges?
First and foremost: Do not ever attempt this unless you accept ALL associated risks.
Second: Never, ever touch the small black primer in the middle of the cartridge unless you are willing to wear the ink, which stains all but permanently.
Third: I will give you the instructions, but advise you to reconsider, and have a pro fill it.
Fourth: Do not fill these cartridges with a "Universal" Ink as no such ink actually exists despite several companies claims. Buy your ink from a reputable refilling business or hire them to do the work. Failure to use the appropriate inks WILL result in crappy printing quality and will likely damage your print heads.
Now, if you're ok with all of the above, go ahead at your own risk.
I will describe the process for the black cartridge, once you're done repeat with the appropriate colour of ink for each of the other three.
You will need: 1 pocket knife, 4 Swine needles with 10-12gauge blunt tip, 1 small set screw or eyelet screw, tape.
Cut the labels on both sides of the bottom cap, then pop it off.
squeeze the two narrow edges of the cartridge with one hand and pull up on the insert with the other. It's a tight fit so this may take a couple tries.
once you have the mylar bag and pump system out of the shell set it gently on a soft surface as the mylar is somewhat delicate.
use the eyelet screw to thead into the small black plug about 3mm, then pull the plug out by tugging on the eyelet screw.
Set this aside and load your needle with ink, the amount you need should be slightly less than the listed volume on the outside shell of the cartridge you're working on.
Insert the tip of the needle 4-5mm inside the filling hole and begin filling slowly, as you aproach 3/4 full tilt the cartridge until the filling hole is on the high side and that corner is facing straight up.
When it gets to the top, retract the needle, reinsert the plug and reverse the eyelet out of the plug. Be sure the plug is all the way in.
Reinsert the mylar and pump section into the shell and recap it, retape the bottom section.
Turn the cartridge so that the other bottom corner is now the high side and allow it to stand for abour 3 hours, continue on to the next cartridge.
When you have completed all four cartridges and allowed them to stand for 3 hours, take them one at a time, insert the needle used for that colour into the ink feed and draw up slightly, pump the primer twice, then draw up again. As long as there is air bubbling up, continue, as soon as you get a short, smooth flow of ink, the cartridge is primed.
Now reposition the cartridges in the printer and you're ready to print.
Clean up any messes you've made with running alcohol as best you can(won't clean perfectly) or with an enzyme based cleaner such as the ones used to clean pet urine(will break down the dyes).
Hope this helps FixYa,
Chris
Posted on May 29, 2009
  • 23 Answers
SOURCE: had printer cartridge refilled but when i put it
I would never use refilled ink. This is a lesson. You can still print, yet the cartridge needs a new "chip" they should have given you when they refilled it. You can try: remove the cart. turn off printer, unplug it, then put old cart back in. Do this three or four times and the memory of the printer can only remember three or four resets and then put refilled cart in. Hope this works for you. I was told this for an HP 7130 (similar, yet older version).
Brock
Posted on Sep 16, 2010
  • 1751 Answers
SOURCE: printer giving 'incompatible ink cartridge' message
replace your cartridge with a new one or refill others old
check here how you can do it your self
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Posted on Oct 30, 2010
  • 239 Answers
SOURCE: I REFILLED MY HP CARTRIDGE WITH BLACK INK 818.
I suspect that your cartridge has a chip in it which is telling the printer that it is empty. You will either have to buy a new cartridge (or good compatible) or try to reset the chip
some advice on methods for resetting chips here
http://www.atlascopy.com/newsletters/Resetting_Cartridge_Ink_Levels.htm
http://www.ink-refills-ink.com/InfoPages/HP%20Resets/reset_57.htm
Posted on Mar 02, 2011
Testimonial: "thanks a lot ..i am trying to do the tape trick. lets see if it works out. i dont want to buy a new cartridge. "
Ink levels lights flashing but ink is full
Might be cartridges are refilled.
You may got doubt why its not measuring the ink levels?. When printer found new catridge(printer/system based on design) will treats that new cartridge installed & estimated level will display fully.After couple of print outs printer/system will displays estimated ink levels depend upon the ink usage. But there is no mechanical ink level sensors or any other device for mesuaring the levels..Once the ink level trated empty you need to replace new cartridge straight away,if you refilled the same catridge it wont measure the levels, because of the cartridge data code already stored in printer. ..
Nov 02, 2011 | HP DeskJet F4280 All In One Printer InkJet
Installed updates now HP printer won't accept refilled ink
HP does not recommend refilling thier tanks, their print heads are built in to the cartridge so if you refilled it before resetting the tanks you will have to go to www.hp.com and run the trouble shooting tool for free to fix your issue. you may have to replace the catridge.
Mar 11, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
Reset ink level on hp 6310 #98 cartridge I have been using refilled cartridges and the in level is ''empty'' even when the cartridge is new and just filled. how can I reset the ink level?
if you are using a refilled catridge you would not get ink levels right.
if you want right ink level use genuine ink catridges.
you can try taking out the catridges turning off the printer and turning it back on and then reinstalling the catridges.it might not help so if possible buy hp ink catridges.
Aug 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Hp 920 xl ink cartridge filling instructions anyone have them
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
Jul 21, 2009 | HP Officejet 6500 Wireless All-in-One...
Empty cartridge
HP Deskjet 3915 Inkjet Printer.
Empty cartidge status is related to the refilled catridges.
Please do not use any refilled cartriges in the above printer.
There is a chance of leakage of ink as a result the entire printer will not work properly.
Buy genuine HP Catridges and install the same in the printer.
If the problem still persits, please lodge a complaint with local HP office and get the cartidge is replaced with a new and genuine one.
Try to make user of Annual Maintence serice contract with local authorized ho Vendor for regular servicing of this printer.
Jul 16, 2009 | HP Deskjet 3915 InkJet Printer
I have refilled my black ink catridge in HP PSC 1410 . now my printer does not print any pages . i have cleaned my printer catridges, still it's not printing any pages . plz tell me the detailed steps to...
Sounds like the printer thinks the cartridge is empty. Old PSC units had a 3 cartridge memory - you kept 3 cartridges and cycled them to trick the printer into thinking it had just received a brand new cartridge, rather than a refilled one.
Jun 16, 2009 | HP PSC 1410 All-In-One InkJet Printer
Can I be able to refill the catridges
Drvirao, if you're talking about just refilling the ink cartridge itself, there are refill kits available for purchase, some for a reasonable price. I've provided a link (just copy the entire link below and paste it into your web browser) I know for sure that HP provides Ink Cartridge Refill kits that you can purchase. I hope that this was able to answer your question.
http://www.google.com/search?hl=en&q=ink+cartridge+refill+kits&btnG=Google+Search
Jan 22, 2009 | HP D1560 Deskjet Printer InkJet
Flashing light check print cartridge
You must replace all ink carts with new ones at the same time. Yeah, this how HP makes its money.
Jan 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart Plus B210A Multifunction Printer CN216AB1H Logo
Seeker5211
Seeker5211
