Question about Emerson Microwave Ovens
Emerson microwave MW8103SS not heating up.
I have emerson mn 9113ss microwave that went dead on me. The fuse and the other electronics are good. When you turn it on it lights up and the timer works. I cannot remember if the turn table spins. It just does not heat up. What can I do to fix this problem?
  • Emerson Master
  • 9,047 Answers
If the turntable in not turning, it's probably be a bad door switch or door switch mount.
See these links:
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
If the turntable does turn, then it is probably a bad connection or component in the high voltage section.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Oct 26, 2012
  • 38 Answers
SOURCE: Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Posted on Mar 15, 2009
bestdarngood
  • 3037 Answers
SOURCE: My microwave does not heat anything. The touchpad, exahustfan, light works. The motor turns on and turn-table works for the number of mins specified but does not warm up the stuff. Please help!
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 26, 2009
SOURCE: Our microwave suddenly stopped heating. The
sounds like the magnatron went out
Posted on Nov 29, 2009
  • 670 Answers
SOURCE: Bosch Microwave HMT8625 range - Microwave not working
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Posted on Dec 24, 2009
lost_sole_28
  • 23 Answers
SOURCE: Emerson Model MWG9111SL Microwave not always working
ok i just opened mine up on counter and found that the white wire on the high voltage transformer had been loose and melted so i put a new female spade connector on and it works fine. i suspect that from a year of use and humm from transformer had loosen it and gotten hot thus loosing connection and getting dirty causing it to overheat and burn off plastic sheilding. easy fix!!!
Posted on Mar 17, 2010
What size is this microwave
Free Emerson Microwave Oven User Manuals - Kitchen ...
kitchen.manualsonline.com > ... > Emerson > Kitchen Appliance Emerson
Products 1 - 48 of 48 - Emerson Microwave Oven and Grill Owner's Manual. Pages: 0 ... Emerson OWNER'S MANUAL Microwave Oven MW8103SS. Pages: 0 ...
Aug 06, 2015 | Emerson MW8108P Microwave Oven
The microwave oven cannot heat up food
Your microwave oven could have magnetron failure but the control circuirty also could be at fault.
Jul 28, 2014 | Emerson MW8103SS Microwave Oven
Emerson mw9113ss wont start after blowing a breaker
Yes most microwaves comes with internal fuse for protection. If you are handy enough you can take the top cover off, identify and find replacement.
Nov 27, 2011 | Emerson Microwave Ovens
My microwave quit working.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches or on a small filter board in the back where the power cord comes in.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron, or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed or virtually zero ohms.
Also, the hood thermostat usually has thinner wires that are not black or white, like the other thermostats' wires.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you.
For more help from Emerson
visit here or get help using your appliance at 1-800-898-9020.
Get help locating an authorized servicer or parts at 1-800-695-0098.
Jan 10, 2010 | Emerson Microwave Ovens
Is there a way to reset the Emerson MW8103SS? It starts and then stops.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively and at no charge, please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to these questions:
- When you say it start and stops, do you mean that it stops when you cooking?
- If so, does the display go off and the oven is totally dead, or does it just stop like someone hit the Stop key, with the display still on?
Oct 10, 2009 | Emerson MW8103SS Microwave Oven
MW8115SS worked perfectly and then went dead
Blown fuse , take the outer cover off and change the fuse. Iff you don't have a fuse use a piece of tin foil until you find a replacement fuse.
Hopefully this helps you out.
Aug 18, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Mw8115ssw no power
There's no reset button, only a a hard reset. Unplug the unit for a minute or so. Then plug it back in and see if ti works.
It may be the fuse, which is usually located on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Jan 12, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Blown Fuse
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Apr 01, 2008 | Emerson MW8775W Microwave Oven
Microwave problem
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open.
When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
See our listing here on FixYa: http://tinyurl.com/yzjozk
For more help from Emerson http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Oct 15, 2007 | Emerson MW8777W Microwave Oven
How do I set the power level?
On our site, we have three different older Emerson microwave manuals you can download free: MW8103SS http://207.234.249.73/mwd/mw8103_om.pdf MW8104SS http://207.234.249.73/mwd/mw8104_om.pdf MW8627W http://207.234.249.73/mwd/mw8627w_om.pdf If none of these is close enough to help you, you can e-mail us a photo of your control panel and we should be able to give you some operating tips. You can e-mail us through our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 28, 2007 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
