Question about Sylvania G-Netbook
Syvania tablet will not connect to wifi because WEP key contains invalid digits for the specified size?
I get an excellent signal strength but when trying to connect to Wifi it says the WEP key I entered contains invalid digits for the specified size?
  • Desiree Bailey Oct 24, 2012
    What should my router settings be set at? Could those settings be the problem?
  • Sylvania Master
  • 32,281 Answers
The WEP key is configured in the router's wireless settings.
Go the the router's wireless setting to get this key.
Posted on Oct 25, 2012
5 Suggested Answers
  • 1267 Answers
SOURCE: trying to connect to wifi
The WiFi software that is embeded into the OS does not work very well. Fortunately digitalgadget.com has a download that somewhat fixes this problem fairly well. The new download is not totally goof proof, but you can work with it.
Go to: http://www.digitalgadgets.com/netbooks/update.html and download the indicated update. You can copy it to a thumb drive and connect the thumb drive to your Sylvania , find it under My Computer and then copy it to your
desktop and run it from there.
Posted on Nov 27, 2010
chetan3792
  • 88 Answers
SOURCE: My netbook is connected and the signal strength is
The signal strength is of the LAN modem. Only when the internet connection is provided to the LAN modem, you will be able to access internet on your notebook.
Posted on Dec 19, 2010
EMKartha
  • 163 Answers
SOURCE: dns error eventhough wifi connection
wifi connection indicates the local connectivity with your modem or router, it has nothing much to do with the router as long as you have a stable ip and a good hardware communication between your lap and the router. DNS represent the server at far which takes care of the DNS zone, to which you connect to get the packets while the lap communicates with another system. Check if the same error is shown if you try another DNS machine. Also ping and see if the DNS ip responds... Good luck.
Posted on Jan 07, 2011
  • 368 Answers
SOURCE: New Sylvania 7 mini tablet...on
Yes in that case it is your router. You need to adjust your setting, could be a web filtering, client filtering, or even time limit filtering that has been turn on. Check your router settings.
Posted on Jan 27, 2011
My tablet says "No Connection". What does it mean? We have wi-fi. . .
Try Switching Aeroplane mode off and on. Sometimes this helps reset network settings on your tablet.
Jun 08, 2017 | Tablets & eReaders
I have a Dragon Touch tablet. won't connect to wifi after WEP is entered and accepted/saved.
Are you still using WEP security? Most devices today no longer use WEP as it is inadequate for serious security. Most devices today are using WPA2 security. If you are no using the proper security you will get an authentication error even if the password is correct.
Dec 25, 2014 | Dragon Touch Tablets & eReaders
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Can't connect Android tablet to Wi-Fi
Android ICS has problems connecting to secured wireless routers, try setting the security to wep if it isn't or if that doesn't work set it to none. This is a known bug in ICS and most vendors will patch it.
Dec 23, 2012 | Computers & Internet
My touch hd could not connect to my home wifi although the connection is visible/detectied.
Even though it is visible and detected the signal strength may not be strong enough to establish a connection. Various factors affect connecting a device to the internet with a WiFi connection, including overall signal strength (G Routers are the weakest), distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your device is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and/or there are obstacles. Try connecting right next to the router and see what happens. Also, make sure you are putting in your router's WEP key in correctly.
May 13, 2011 | Computers & Internet
I just got a new tablet and need to learn how to connect it to the internet. how do i set up the wifi?
hello in your system you will find the built in wifi you will need to open this and search for networks most networks will have security like wpa or wep ,wep you can connect to ,look on the net for this program .....Netopia wep key depending on your location you will find alot networks .if you are planning on using a modem this can be easily installed ,via usb ,,,,,hope this helps you goodluck
Mar 23, 2011 | PANDIGITAL Digital Book 843967071153...
My Ipod touch is not connecting to a wifi which has been working up until 2 nights ago, it still says it has medium signal strength, but if i open the itunes store or any other sort of internet connection,...
Have you had a software upgrade? I had exactly the same problem with a brand new 3rd gen iTouch and it turned out to be a problem with the itouch and the wifi encryption. Mine showed it was connected to the network but wouldn't access anything (invalid argument etc). I tried everything but no joy. Eventually I fixed it by changing the router's encryption from WEP to WPA2-PSK. Fixed it like magic. Where there had been no router or DNA data before, they were suddenly filled in. The key was different but was still on the bottom of the router. I had to re-enter the key on my wireless laptop2_bing.gif but that was a small price.
You can get into the router set-up page through your web browser. I found a guide on You Tube.
Jan 18, 2010 | Apple iPod touch
Wi-fi connection does not work
go to settings and wifi...look for your network and tap on it.
Join your network and if it is secure it is asking for the WEP key which is on the label of the router.
Enter that kep and it should join.
if it is truely an unsecure wifi you should be able to get right on by joining it.
You may be seeing full signal but it may be your neighbors or next door
Good Luck
Mar 10, 2009 | Apple iPod touch
Sylvania G-Netbook Logo
64 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
