Question about Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer
I have a srm 210 echo trimmer just will not run new air filter spak plug
  • 718 Answers
Clean the carb and give new gas.
Posted on Oct 26, 2012
SRM 2400 trimmer. Why doesn't it start?
Ralph, if you are getting fuel, spark and have compression , I suspect the muffler screen is plugged. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Small Engine Repair Cleaning Carbon Buildup on the Exhaust Port Muffler on...
Echo trimmers and loss of power EXHAUST PORT CLOGGED
Symptoms Repair Of Clogged Spark Arrester On Grass Trimmer
My Aunt Echo PB 2100 Blower with Clogged Spark Arrestor Screen
Apr 17, 2016 | Echo Garden
How do I fix a echo srm 210 weedeater that starts but will only run a few seconds?
Try calling echo and ask for tech support or go online to get the phone # or check you tube to see if they have a video on it
Apr 05, 2016 | Echo Garden
Echo srm-210 powers up fine on a flat surface, but it cuts out after a few seconds in the upright (usable) position. I rebuilt the carb, cleaned muffler screen, good gas and fuel filter. tank lines seem...
Make sure you rebuilt the carb with a carb kit. Put a hose on each pipe coming out of the carb and blow and suck on them. One should seal completely and one should provide vacuum. If there is a leak, you need new check valves. If you rotate the trimmer and it runs poorly, you may have a pierced diaphragm.
Oct 22, 2013 | Echo Zama Carb Kit For Shc210 For Rbk66b...
Echo srm-210 weed eater will not run at high rpm, have new fuel lines & filter, new air filter, new carb. What the hell !!!!
If everything is new than something is out of adjustment. Try readjusting high RPM needle valve if it has one. Go to smalleng.com and look for tutorial or you tube has a lot of interesting tutorials on this kind of thing. Good Luck...
Jun 04, 2011 | Garden
My Echo Leaf Blower (PB-251) will not run at high speed. It is running to rich. Help please. Charlie
I've been fighting with an Echo PB-251 blower and an Echo SRM-225 string trimmer since near the end of last lawn season (this is the forth season I've had them). Along comes a thread on a firearms forum and lo and behold the answer to the problem is spelled out in terms even I can understand.
After reading that thread (which attributes the problem of the engine bogging down when throttle is activated to collapsing fuel lines) I was going to just replace the fuel lines, but I discovered that there are kits that include new fuel lines, rubber grommets, filters, clips and cap seals for about $13.00 each. Hell, the kit for the SRM-225 even provided a new primer bulb. Ten minutes after the UPS truck delivered them to my door I had both machines running like new again. If you've tried other things and it still hasn't worked I highly suggest you try this.
Jan 05, 2011 | ECHO, Inc. PB-251C Handheld Blower
How to add line to an echo srm 210 weed trimmer
See pages 27 and 28 of the owners manual here:
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
This certainly explains it better than I can.
Oct 01, 2010 | Echo Garden
Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
Sep 19, 2009 | Echo Rapid Loader, Trimmer Head
Need to install new lever trigger lockout but can't figure out how to install spring on echo trimmer srm 210
Navigate to your exact model using Echo's public website.
Click the "WEB-PLUS PARTSEARCH" link at the bottom right of their homepage.
Sep 17, 2009 | Echo Garden
Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer Logo
277 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
