Question about Black & Decker Steam Xpress AS250 Iron with Auto Shut-off
I have steamxpress 620 how can i open it to fill water?
2 Suggested Answers
johnny5846
  • 379 Answers
SOURCE: steamxpress 620 filling in water
http://www.useandcaremanuals.com/pdf/S600Series536.pdf
as i suspected , i looked at your user guide here , its like any other iron , when its standing upright , there is a hole sorta on the top pour water in there and a site glass in the handle area will show you how much is in there . hope that a fix ya .
Posted on Jan 02, 2009
Open steamxpress 680 for thermal fuse
If there is a recall on it, send it back! This is a fire hazard.
Nov 25, 2013 | Black & Decker Irons
How to feel water in iron??couldn't find opening way?its Moulinex iron
To fill an iron which doesn't appear to have an opening with water - such as the moulinex chronomate 35 - you need to pull off the sprayer button. That should reveal the opening!
May 04, 2010 | Moulinex Brio IM3070 Iron with Auto...
How to clean brown water coming out of iron
The reservoir of your iron needs cleaning if it looks as though small deposits are being left in the small holes on the soleplate. Typically, the deposits are minerals from the water that you are using in the reservoir. The deposits may have a white color, and they may resemble salt.
Cleaning the reservoir requires the use of white vinegar and a clean rag. Fill the reservoir of a cold iron at least one fourth of the way with white vinegar. Turn the iron on and place it on the steam setting. Steam iron the clean rag until the reservoir is completely empty.
If the deposits are still visible to you, you will need to fill the reservoir with clean water and steam iron a rag again. If the deposits are still visible to you after this, you will need to repeat the process with vinegar until the deposits are no longer apparent.
Rinse the reservoir thoroughly with clean water by filling it completely and then emptying it completely. In order to avoid mineral buildup and deposits, use only distilled or purified water in the reservoir. If you continue to use tap water, simply remember to clean the reservoir periodically.
Vinegar has a strong smell associated with it, especially when it is heated. Ventilate the area where you are working as much as possible, by opening windows, turning on vents or fans, or keeping the door open.
The water you use to fill your iron is causing this problem. Once you clean it use distilled water available by the gallon at the grocery store. Joe
Apr 09, 2010 | Rival IR620 Iron
How to open to get water inside
No need to open iron! You just unplug the iron. Hold the iron upright. Using a clean cup, pour water into the "open" WATER FILL HOLES just above or in front of the Temp. Select Dial. Watch the water window on the left. When water level reaches MAX, you are filled. Plug in and use. Refill as needed. Ref. - Page 8 in the instruction pamphlet.
Oct 18, 2009 | Black & Decker Quick N Easy X420 Iron
How do you fill the water tank on the steamer conair model GS15RN?
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Jun 04, 2009 | Conair Compact Garment Steamer Iron
How to put water in the Tefal pro 2500
This type of iron is called a steam station iron.
The box is the water tank and it is this that you need to fill with water. You should be able to find a small spout on the water tank in order to fill it. These irons produce a huge amount of steam and should make the ironing a breeze once you get used to it.
Feb 07, 2009 | Tefal Irons
Steamxpress 620 filling in water
Jan 02, 2009 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker SteamXpress 620
Check the cord...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 11, 2008 | Black & Decker Steam Xpress AS250 Iron...
Short circuted
It must be disassembled. To do that you need special a screwdriver.When you have carefully disassembled it, all ruber seals and gaskets must be thoroughly cleaned from water salt deposits and refitted correctly because may be difficult to find spare parts for replacement.
i.e. If you have not the experience to carry out the repairment by yourself, it is better to think about buying a new one.
See "Note" at the site below. Good Luck !!
http://www.morekitchenappliances.com/Black-and-Decker-AS250-BND1003.html
We're sorry but it appears the product you are looking for (Black & Decker AS250 AS250 SteamXpress Iron SKU: BND1003) is no longer available. This is usually because the manufacturer no longer makes this product, or because we have decided to no longer offer it. If you have specific questions about this product please call us at (800) 632-1743 and we can try to help you.
Jan 28, 2008 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off Logo
41 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
