Question about Dennis Z Jiang GWT Mobile PhoneGap
Android eclipse + phonegap. Cannot tab to 'select'
Using phonegap with eclipse, my html is written where I have about 10 'input type='number' tags and about 10 'select' tabs. When the user is using their phone with this app types a number in the 'number' box and presses 'Next' on their phone's soft keyboard it ALWAYS tabs to the next 'input type='number' box, but i need it to tab to a 'select' box. I've tried adding tabindexes to my html but that doesn't help. If there is a way to disable the 'Next' key on the soft keyboard that would be awesome. But I have no idea how to do that.
Using my phone as mobile hotspot how do i get my network ssid.
You can use your Android phone as a portable hotspot and get your iPad, iPod Touch, or any other wireless device online. This is a great save when there are no available wireless connections available.
1. Go to the Home screen.
2. Select the Menu key.
3. Select Settings.
4. Select Wireless & networks.
5. Select Tethering & portable hotspot.
6. Select Portable Wi-Fi hotspot checkbox.
7. Select Portable Wi-Fi hotspot settings.
8. Select Configure Wi-Fi hotspot.
9. Input a Network SSID for your connection.
10. Select a security protocol. Options are Open andWPA2 PSK.
If you select WPA2 PSK, input a password for the connection and then select the Save button.
You will use the Portable Wi-Fi hotspot checkbox from above to enable and disable the connection. Once the connection is active, go to the device you wish to connect and configure its wireless connection to the Network SSID for you Android device and input the password (if you are using WPA2 PSK). You now have wireless access for your iPad, iPhone Touch, Zune HD, etc. anytime there is a cellular connection for your Android phone.
Aug 08, 2014 | Cell Phones
3. Select Settings.
10. Select a security protocol. Options are Open and WPA2 PSK.
-regards and update me
How do I name my eclipse mp3
You do it through Windows Media Player after connecting the Eclipse to a PC. This is how it's described in a manual on the Eclipse site.
Connecting to a PC - Loading files
Using Windows Media Player (Note: you must use Windows Media Player 10 or later to use this feature.)
  • Open Windows Media Player and connect the player to a working USB port. Windows Media player will prompt you with a setup screen asking you to name the MP3 player.
  • Once you have named your MP3 player, select Finish, and your Windows Media Player will open to the Sync tab.
http://www.eclipsemp3.com/180G2.pdf
Feb 01, 2014 | Audio Players & Recorders
Eclipse 3d immersive e777
Have just un-boxed with same problem. I kept changing out-put on Windows 7, selecting 'extend projector' and 'duplicate' under display settings while changing input source from HDMI 1 to 2 for about 2 mins and I'll be damned, it worked!
Good Luck
May 23, 2012 | Blenders
How to recover deleted text messages
As a matter of fact, every time you sync data between iPhone and iTunes, all previous data will be automatically backed up by iTunes and stored as a .sqlitedb file, which will be updated along with the later sync continuously. But those backup files can't be viewed or taken out unless you use some software using special algorithms to extract. Learn how to recover your iPhone data with step by step guides.
Mar 27, 2012 | Pinger Textfree Unlimited - Send Text...
Just installed a ZR24W monitor, screen blacks out after 10 minutes with a message saying 'Input signal out of range, change settings to 1920x1200-60hz'. The monitor was set to this resolution &...
You will need to adjust the refresh rate of your system.
1) Right click on the desktop and go to properties.
2) When the Display Properties window opens go to the Settings tab.
3) The go Advanced.
4) Once ni the advanced screen go to the Monitor tab.
5) Under screen refresh rate select around 60Hertz. (Make sure the box next to "Hide modes that this monitor cannot display" is ticked.
6) The click OK. And OK again to exit Display Properties.
May 26, 2011 | HP Smart Buy ZR24W LCD Monitor
I have just purchased an Acer Iconia A500 Android 3.0 tablet. The Android operating system is totally new and there for totally alien to me. Is there a "how to use" manual for Android? How do I...
You can download the User manual @ http://us.acer.com/ac/en/US/content/drivers
From the box, Select -> Tablet -> ICONIA Tab -> A500 -> Confirm Selection.
Download & install the USB drivers for your Tablet. As for the User's manual click on the "Document" tab to download. (If your USB drivers is already installed on your Tablet, not necessary to reinstall the drivers)
Could not tell you whether your video camera software is supported by "Android 3.0 Honeycom" OS.
As for the USB connection to portable storage device "transfering or adding files" it is more or less similar to that in PC/laptop system.
Hope it will help & thank you for using Fixya.
May 23, 2011 | Google Computers & Internet
Give the complete process of download and install eclipse
Well... That depends on what you are using Eclipse for. I will assume you are using it for Android development. If you are not, hopefully this will provide some insight on your application of Eclipse
Step 1. Download and Install the Java Development Kit (JDK) here.
Step 2. Download and install the Android SDK. Get it here
Step 3. Download Eclipse Classic Here (as zip file)
Step 4. Extract Eclipse to a directory where you can remember.
Step 5. open eclipse.exe , then select Help > Install New Software....
Step 6. Click Add, in the top-right corner.
Step 7.In the Add Repository dialog that appears, enter "ADT Plugin" for theName and the following URL for the Location: "https://dl-ssl.google.com/android/eclipse/" Note: If you have trouble acquiring the plugin, try using "http" in the Location URL, instead of "https" (https is preferred for security reasons).
Step 8. Click OK.
Step 9. In the Available Software dialog, select the checkbox next to Developer Tools and click Next.
Step 10. In the next window, you'll see a list of the tools to be downloaded. Click Next.
Step 11. Read and accept the license agreements, then click Finish.
Step 12. When the installation completes, restart Eclipse.
p.s. When I downloaded the 64 bit edition of the JDK, the Android SDK could not seem to detect it. So, I then downloaded the 32 bit version of all software (JDK, SDK, and Eclipse) and had no problems since. Also, even if you are not using Eclipse for android dev, after following the above directions, you will still be able to use it for java development.
Jan 28, 2011 | Computers & Internet
Dennis Z Jiang GWT Mobile PhoneGap Logo
239 people viewed this question
Top Dennis Z Jiang Apps Experts
Are you a Dennis Z Jiang App Expert? Answer questions, earn points and help others
