Question about HP LaserJet 6L Printer
Help in replacing the cartridge
I would like some help in figuring out how to install the new cartridge
thank you
  • klkdagostino Jan 02, 2009
    i have lost the manual to the laserjet 6l and need some assistance in replacing the cartridge.
    Genius:
  • 2,120 Answers
Pull the front cover towards you. Instuctions come with the new cartridge.
Posted on Jan 03, 2009
Ink cartridge doesnt any help
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on.Figure 1: Press the On button to turn the product onc00442142.gif1 - On buttoncaution.pngCAUTION:If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One.Figure 2: Open the access doorc00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.Figure 3: The print carriagec00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: The print cartridges in the proper positionc00442144.gif1 - Print cartridge slot for the tri-color print cartridge2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Step two: Install the new print cartridgeBack to top
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.Figure 5: Remove the tapec00442146.gif1 - Copper-colored contacts2 - Plastic tape with pink pull tab (must be removed before installing)3 - Ink nozzles under tapecaution.pngCAUTION:Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Insert the print cartridgec00442148.gif
  3. Close the print-carriage access door.Figure 7: Close the access doorc00442149.gif
Step three: Align the print cartridgesThe HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. Use the following steps to align the print cartridges from the control panel.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray, and then press OK .
  2. The HP All-in-One prints a print cartridge alignment sheet.note.pngNOTE:If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  3. Lift the lid. Place the top of the alignment page face down in the left front corner of the scanner glass. Close the lid.Figure 8: Load the alignment sheet on the glassc00443602.gif
  4. Press OK to begin the alignment.
  5. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Oct 28, 2011 | HP Officejet 5610 All-In-One InkJet...
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
Would like instructions for installation of new ink cartridge in 6500A printer
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube Step one: Open the All-in-One
  1. Press the Power button (c01602202.gif ) to turn on the product, if it is not already on.
  2. Open the cartridge-access door. The carriage moves to the center of the product. Wait until the carriage stops moving before proceeding. Figure 1: Open the cartridge-access doorc01638336.gif
Step two: Replace the old cartridge
  1. Press in the tab on the front of the cartridge, and then pull it out and up to remove it from its slot. Figure 2: Remove the cartridge from its slotc01495178.gif
    CAUTION: Do not lift the gray latch next to the carriage to install the cartridges. Doing so can result in incorrectly seated ink cartridges and printing problems. The latch must remain down to correctly install the ink cartridges.
  2. On the replacement cartridge, pull the orange pull-tab straight back to remove the plastic wrap. Figure 3: Remove the plastic wrap c01493650.gif
  3. Twist the orange cap counterclockwise to snap it off the cartridge. Figure 4: Remove the orange cap c01495123.gif
  4. With the cartridge contacts facing the printhead, slide the cartridge into the correct slot. The color-coded icons on the cartridge and in the printhead indicate the correct slot. Figure 5: Insert the ink cartridge c01493652.gif
  5. Press down on the ink cartridge until it clicks firmly into place. Figure 6: Press the cartridge into place c01493653.gif
  6. Repeat these steps for each cartridge that you want to replace.
  7. Close the cartridge access door. The carriage moves to the right side of the product.
Jul 27, 2011 | HP Officejet 6500 Wireless All-in-One...
I replaced new cartridge but show up 'insert cartridge' repeatly. i insert cartridge.but again again repeat show up 'insert cartridge' what is problem? please help me.
  1. Push down on the cartridge to release it from the carriage, and then lift it up and out of the product. Figure 2: Remove the old cartridge c01747836.gif illustration of removing the old cartridge
  2. Remove the new cartridge from its packaging, and then pull the pink tab to remove the clear protective tape. Figure 3: Prepare new cartridge c01745262.gif illustration of preparing a new cartridge CAUTION: Do not touch the copper-colored contacts or re-tape the cartridge. Figure 4: Do not touch contacts c01746332.gif warning not to touch the cartridge contacts
  3. Hold the cartridge with the label on top. Figure 5: Label on top c01668109.gif illustration of holding the cartridge with label on top
  4. With the copper-colored contacts facing into the carriage, insert the cartridge into the carriage at upward angle. Push the cartridge up, and then into the carriage until it snaps into place. Figure 6: Install cartridge c01745263.gif 1 - Insert cartridge 2 - Push cartridge up 3 - Push cartridge in illustration of install the cartridge
    NOTE: If the cartridge moves loosely in the carriage, it has not clicked into place. Repeat this step.
  5. Close the cartridge compartment cover, and then the control panel.
Step three: Align the cartridge
  1. Press the Start button (c01371053.gif ) on the product control panel.
  2. Press 1 to indicate you installed a new cartridge. The product prints an alignment page and 06 [01-11] displays on the control panel. Figure 7: Alignment page prints c01745264.gif illustration of alignment page printing
  3. Review the alignment page, and then select the number under the straightest line.
  4. Press that number on the keypad, and then press the OK button (c01335940.jpg ).
May 21, 2011 | HEWLETT-PACKARD HP 2140 Fax
My hp d2360 is not working properly and i bought new cartridge but printer wasnt recognize the cartrige..
Please follow the steps below to install the Cartridge:
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Printer cover openc00658567.gif
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    NOTE: HP recommends using a print cartridge protector to store an opened print cartridge for later use. Figure 2: Print cartridge being inserted into a print cartridge protectorc00658568.gif
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 3: Removing the protective tapec00658569.gif
    CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 4: Print cartridge facing upc00658570.gif 1 - Ink nozzles 2 - Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 5: Installing the print cartridgec00658571.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Mar 07, 2011 | HP Deskjet D2360 InkJet Printer
How do I remove and replace the ink catridge ?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01429130&cc=us&lc=en&dlc=en&product=3645100&tmp_track_link=ot_search
Please follow this link and well you would have your ink cartridges replaced without a problem.
Otherwise this is what you do
Step one: Remove the old cartridge
  1. Press the Power button ( c01983533.gif ) to turn on the HP product.
  2. Open the front access door. The carriage moves to the far right side of the HP product. CAUTION: If the HP product is off when the front access door is opened, the HP product will not release the cartridges. Figure 1: Open the front access doorc01429211.gif
  3. Wait until the carriage is idle and silent, and then lightly press down on a cartridge to release it.
    • To replace the tri-color cartridge, remove the cartridge from the slot on the left.
    • To replace the black cartridge, remove the cartridge from the slot on the right. Figure 2: Remove the black cartridgec01429212.gif
  4. Pull the cartridge toward you and out of its slot.
Step two: Prepare the new cartridge Use the following steps to prepare the new cartridge for use in the HP product. Which cartridges you use depends on your country or region. To check the cartridge compatibility for your product, right-click this link, HP SureSupply , and then click Open in New Window . If your language or country does not display next to the globe icon (c01906983.gif ) select your language and location.
  1. Remove the new cartridge from its packaging. Be careful to touch only the black plastic.
  2. Use the pink pull tab to remove the plastic tape gently. Figure 3: Remove the tapec01367670.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the contacts or ink nozzlesc00442147.gif
Step three: Replace the old cartridge Use the following steps to replace the old cartridge.
  1. Hold the new cartridge with the HP logo on top, and then slide the cartridge at a slight upward angle into the empty cartridge slot. Push the cartridge in firmly until it snaps into place.
    • To install a tri-color cartridge, insert it into the left slot.
    • To install a black cartridge, insert it into the right slot. Figure 5: Insert the black cartridgec01429213.gif
  2. Close the front access door.
  3. An alignment page prints. You do not need to do anything with this page yet. Continue to the next step.
Step four: Place the unused cartridge in a cartridge protector If you are temporarily removing a working cartridge (for instance, removing a black cartridge in order to install a photo cartridge), put the cartridge that you are not using in a cartridge protector. NOTE: Cartridge protectors come only with photo cartridges. If a cartridge protector is unavailable, store the unused cartridge in a rigid, airtight container (not a plastic bag). If unprotected, the cartridge can dry out and become unsuitable for use. Step five: Align the new cartridge The HP product prints a cartridge alignment sheet when you install new cartridges.
  1. When prompted, load unused, plain white, U.S. letter or A4 sized paper into the input tray, and then press OK on the HP product control panel.
  2. Lift the scanner lid.
  3. Place the alignment sheet on the scanner glass so that the top of the sheet is on the right side with the text facing down. Make sure that the sheet is aligned with the right front corner of the scanner glass. Figure 6: Place the alignment sheet on the scanner glass
  4. Close the scanner lid, and then press OK on the HP product control panel. The HP product aligns the cartridges.
Oct 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
I don't know how to install the cartridgre on my new printer J 3680 Could you please tell me how? Thanks,
Follow the instructions below to install the print cartridges for the first time. Installing print cartridges Step one: Install the print cartridges Follow these steps to install the cartridges.
  1. Open the cartridge door. The carriage moves to the far right side of the product. Figure 1: Open the cartridge doorc01133347.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab. Figure 2: Remove tape from cartridgec01107115.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts. Figure 3: Do not touch the ink nozzles or copper contacts.c01107116.jpg
  3. Slide each new cartridge forward into the empty slot. Then gently push theupper part of the cartridge forward until it clicks into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black cartridge into the right slot.
    Figure 4: Insert the cartridgec01107117.jpg
  4. Close the cartridge door.
Step two: : Align the print cartridge The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or byusing the software you install with the product. Aligning the cartridgesensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
NOTE: If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the inputtray, and then try the alignment again.
Sep 13, 2010 | Office Equipment & Supplies
How do you open for ink replacement?
Removing an empty print cartridges Follow the steps below to remove an empty print cartridge:
  1. Press the Access Cartridge button on the control panel. The cartridge carrier moves to the remove/install position. Figure 1: HP Fax 1040/1050 control panelc00253378.gif 1 - Access Cartridge button
  2. Open the control panel and cartridge compartment cover (it will click and remain open). Figure 2: Opening the control panel and the compartment coverc00253379.gif 1 - Control panel 2 - Cartridge compartment cover
  3. Pull the cartridge toward you until it releases from the print cartridge cradle and then remove it. Figure 3: Removing an empty print cartridgec00253380.gif 1 - Pull cartridge towards you 2 - Remove cartridge from print cartridge cradle
Installing a new print cartridge Follow the steps below to install a print cartridge.
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape using the pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: HP 20 print cartridgec00259017.gif
  2. With the cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place. Figure 5: Inserting a new print cartridgec00253382.gif 1 - Insert the print cartridge into the print cartridge cradle 2 - Push the top of the cartridge until it clicks into place NOTE: If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
  3. Close the cartridge compartment cover and control panel.
  4. Press the Start/Enter button.
  5. On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old. NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
for more information follow the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00253364&tmp_task=useCategory&lc=en&dlc=en&cc=ca&lang=en&product=425911
Jun 18, 2010 | HP 1040 Plain Paper Inkjet Fax
Test page printing at the time of printer powered on
s.gif Solution minimtop.gif The product aligns the print cartridges every time that print cartridges are installed or replaced to ensure the highest-quality prints. The alignment page will continue to print every time that the product is turned on or off until the alignment process is completed. NOTE: If you remove and install the same print cartridge, the unit will NOT align the print cartridges. The unit remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. Follow the steps below, in the order presented, to correctly complete a print cartridge alignment. s.gif Step one: Remove the print cartridges minimtop.gif
  1. If the On/Resume button is not lit, press the On/Resume button to turn the product on. Figure 1: Press the On/Resume button to turn the product on c00316907.gif
  2. Make sure the paper tray is down and there is letter or A4 unused plain white paper loaded in the paper tray.
  3. Lower the access door until it stops. Figure 2: Lower the access door c00316908.gif Make sure the print carriage moves to the center. Figure 3: Print carriage in the center of the printer c00316909.gif
  4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it. Figure 4: The print carriage c00316910.gif
    • If replacing the black print cartridge, remove the print cartridge from the slot on the right.
    Figure 5: The print cartridges in the proper position c00316912.gif 1 - Tri-color print cartridge 2 - Black print cartridge
  5. Pull the print cartridge toward you out of its slot.
s.gif Step two: Install the new print cartridge minimtop.gif
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward at a slight upward angle into the empty slot. Using your index finger, push the print cartridge forward until it clicks into place. Figure 7: Insert the print cartridge c00316911.gif
  3. Close the access door.
s.gif Step three: Align the print cartridges minimtop.gif If you are installing a new print cartridge, the product begins to print a print cartridge alignment sheet. This may take a few minutes.
  1. Lift the lid of the product.
  2. Place the top of alignment page face down in the left front corner of the glass. Figure 8: Place the alignment page face down c00316913.gif
  3. Close the lid.
  4. Press the Scan button.
  5. The On/Resume light will blink during the alignment process.
  6. After the On/Resume light stops blinking, alignment is complete.
Feb 26, 2009 | HP PSC 1410 All-In-One InkJet Printer
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
HP LaserJet 6L Printer Logo
35 people viewed this question
Ben Johnson
