Question about HP Officejet 6100 e-Printer Wireless Color Printer
HP 6100 and wpa2 mobile hotspot
Print from laptop to HP printer using mobile hotpsot
4 Suggested Answers
SOURCE: my 6100 hp inkjet printer will not print .
just push the printer cartridges
Posted on Jan 13, 2009
  • 96 Answers
SOURCE: Z-6100 large file print problems
do you get any error codes? is this postscript? are you sure the upload of the firmware worked correctly? sorry for all the questions.
Posted on Sep 28, 2009
  • 100 Answers
SOURCE: I use a HP photosmart all in one printer 6100 and
Several HP all in one owners have had similar problems. My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to your HP 6100 printer. acca299.jpg
Posted on Dec 28, 2010
How do I use my Moto X to get internet on my IPad mini
Contact your service provider and ensure they add mobile hotspot feature to your account. Then configure it using wpa2 and enter the wireless WiFi password when you have enabled it on your phone. Be sure to turn it off when not in use.
Mark
Motorola Support
Feb 28, 2015 | Motorola Mobility Moto X
How to turn on wi fi on hp 6100
here is a link of the manual on how to set up your wifi on the hp 6100 very easy to read
http://h10032.www1.hp.com/ctg/Manual/c03246247.pdf
Oct 12, 2014 | HP Hewlett-Packard - CB863AB1 Officejet...
Using my phone as mobile hotspot how do i get my network ssid.
You can use your Android phone as a portable hotspot and get your iPad, iPod Touch, or any other wireless device online. This is a great save when there are no available wireless connections available.
1. Go to the Home screen.
2. Select the Menu key.
3. Select Settings.
4. Select Wireless & networks.
5. Select Tethering & portable hotspot.
6. Select Portable Wi-Fi hotspot checkbox.
7. Select Portable Wi-Fi hotspot settings.
8. Select Configure Wi-Fi hotspot.
9. Input a Network SSID for your connection.
10. Select a security protocol. Options are Open andWPA2 PSK.
If you select WPA2 PSK, input a password for the connection and then select the Save button.
You will use the Portable Wi-Fi hotspot checkbox from above to enable and disable the connection. Once the connection is active, go to the device you wish to connect and configure its wireless connection to the Network SSID for you Android device and input the password (if you are using WPA2 PSK). You now have wireless access for your iPad, iPhone Touch, Zune HD, etc. anytime there is a cellular connection for your Android phone.
Aug 08, 2014 | Cell Phones
3. Select Settings.
10. Select a security protocol. Options are Open and WPA2 PSK.
-regards and update me
Need password to use my phone off wiifi on my laptop
I have our laptop and xbox running off phones hotspot. what I did was go on your phone to the configure wifi hotspot. make sure u configure wifi hotspot first.it will ask for a network name, then password. I picked out my own then saved it.on my phone it shows phone wpa2 psk portable wifi hotspot. then u will click on wi fi hotspot should read portable hotspot phone active. now go to laptop look under the wireless internet should show a list of available networks. u should c the one u created on your phone click
Jan 06, 2014 | Computers & Internet
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Hp dv7 won't connect to mobile hotspot
RUNNIG WIN XP? READ THIS http://www.fixya.com/support/r7858944-working_widows_wireless_networks
Apr 11, 2012 | HP Pavilion dv7-1132nr Notebook PC
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
Apr 29, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have a hp 6100 Series printer. My computer
is this an hp z6100? reload your print drivers.
Aug 11, 2009 | Office Equipment & Supplies
HP Officejet 6100 e-Printer Wireless Color Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
