WD e101559 my WD 1 terabyte portable hard drive not working. blue light is blinking, if connect i can hear drive is working, but i can't see hard drive on my lap top , so what can i do?
  • 244 Answers
SOURCE: Problem setting up Enclosure
Please check if your jamper of the hardrive must be set to primary settings. Or possible your usb connector having lost contact problem.
Hope this will be helpful to you.
Posted on Oct 26, 2007
darkoh69
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
ipodslinger
  • 688 Answers
SOURCE: SeagateFree Agent Go 120 G.B external portable Hard Drive
you will need to install the drivers for your drive.
xp doesn;t recognize 2.0 usb unless you install drivers and have a usb 2.0 port
but install the drivers and you should get it to recognize
you can go to control panel, system and device manager.
look for a usb device that is not working and right click install drivers or update drivers.
See if it comes up.
Once it does you will see it in the device manager under disk drives
Posted on Jun 05, 2009
Crankstart
  • 696 Answers
SOURCE: My wd elements hard drive of 1 terabyte will not turn on
Usually if this happens it's either a dead AC adapter or a failed circuit board inside. If you have nothing crucial on the drive take it back to the store you bought it from or contact Western Digital for warranty.
If you do have crucial files and don't want to loose them by simply warrantying the drive, take it to your local PC store and void your warranty by having the techs there move you hard drive into a new enclosure for testing. If it works in the new enclosure buy it and be on your way. If it doesn't your problems are more severe and will require some specialized assistance from a Data Recovery Pro. If this is the case ask the techs to place the HDD in a anti-static bag then reply to me with your Country, State, City and I will refer you to a nearby Pro who can access your files and save them for you.
Hope this helps FixYa,
Chris
Posted on Aug 19, 2009
lock123
  • 6831 Answers
SOURCE: WD portable hard drives not recognized
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
WD Myworldbook white strip flashing
The 'blinking' light simply means the unit needs tending to. Once acknowledged, via config, the flashing light will stop. Sometimes your anti-virus program will block you from getting into config. So you might have to turn your AV off.
Sometimes the blinking starts because the drive is over 95% full and sometimes it means one of the drives inside is failing or has died.
Run the WD Discover Tool, go into to "configure", & acknowledge that over 95% of the drive is used if that's the problem. Once you do that, the blinking light will go away & work like it did prior to the blinking light.. If a drive is failing then you might need to RMA it.
Jun 10, 2012 | Western Digital My Book World Edition II...
My WD element extrenal hard drive won't open. i can see it in my devices, and the blue light stays on. it also makes the sound saying it's connected but I can't see the device in my comput
First thing, try to change the cable, try a different one, then if it does not work, try to connect the hard drive on another computer, and changing cables as well. This will help you to narrow down the problem to find out exactly what the matter is. If the Hard drive spins properly and it does not produce any click-click sound then it is fine. If all the above fail, then you have to slave the hard drive using its internal SATA connection. You have to open up the hard drive and remove the pin that connects the hard drive to the cable. This will enable you to see the SATA connection. Slave the Hard drive on a desktop computer and see if you can gain access to it. If you can, then consider replacing both the cable and the pin that connects the cable to the hard drive. If your hard drive just spins and you can not access it while its a slave to another computer, then the hard drive has a problem.... Try the methods above, i believe your hard drive did not go this bad...
Mar 26, 2012 | Western Digital Elements powered by WD 320...
I have a Samsung 500 GB portable drive which containes WD 5000BEVT Scorpio Blue drive inside. It is not recognised on my two laptops (1 running XP & other Win7). At times, it is recognised when I...
does the drive make any noise? does it whine or click? do you have both data AND power cables connected?
also, can you hear or feel the drive spin up when you provide power? i have a scorpio black in my laptop, and although it is very quiet, i can definately tell just by the feel and slight noise when it is running (without the hard drive indicator light being taken into consideration)
feel free to contact me directly i would like to help
Jul 06, 2011 | Computers & Internet
My hard-disk is on-Warrenty basis.On hardisk light is blinking but unable to detect on pc ,So Please tell me the procedure how to recover my data. P/N-WDBAAA5000ABK-00 S/N-WXM1A80N4025N
Can you hear the drive spinning when you connect it to your computer? A spinning sound means your external drive is being powered by the USB from your computer - there are several reasons the drive is not being recognized.
If you are not hearing any spinning sound the drive could be damaged.
Does the drive get recognized by any another computer? If yes - check disk management and see if security is enabled on the drive. Also - check to see if there is a drive letter assigned to your external hard drive.
Link
Feb 28, 2011 | Western Digital WD Passport 250GB Portable...
I droped my firelite and now it won't read. I plug it in and hear the disc startup, the blue light flashes once and then three times in a row. Can I transfer the disc to another housing?
it sounds like you have damaged the disk itself. most portable hard drives are just notebook drives in portable enslosures. The same think happened to my WD portable and I had to trash it. I saw the same symptoms and only after playing with it could i get it to read but only with 2mb since the disk was cracked. hope this helps you.
Apr 08, 2010 | SmartDisk FireLite 40 GB Hard Drive
WD320GB hard drive not working
Are you using a double power USB cable, which normally comes with W/D hard drives?
Also if the light on hard drive blinks the drive is not getting enough power from the USB port.
All the best!
Aug 11, 2009 | Western Digital WD Passport 250GB Portable...
WD Passport not recognized
I added my WD Passport 80 GB it was seen in My Computer one day then i tried it again and it doesn't appear it on (humming and the blue lights on to) but still no WD Passport (F:\Removable disk) please help
Jun 18, 2009 | Western Digital Passport WDXML800UE...
Jun 01, 2009 | Western Digital My Book Essential 1TB...
WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
Mar 25, 2009 | Western Digital WD Passport 250GB Portable...
Computers & Internet Logo
1,260 people viewed this question
David Payne
David Payne
