Question about Gbc Combbind C110E Electric Binding System
Gbc c110e how to open cover - Gbc Combbind C110E Electric Binding System
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Bindmate GBC has paper stuck
Pull out the papers slowly one by one starting from the page on top. They'll probably rip but it's the only way I've found to get them out (I've tried unscrewing the covers but the thing doesn't pop out). For the next usage only punch a max of 4 pages.
Oct 18, 2013 | Acco Brands Corporation GBC BindMate...
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
HTC RADAR C110E DRIVER
i need a solution to connect my htc radar c110e with my pc
Jan 15, 2013 | HTC Computers & Internet
My gbc heatseal h300 wont feed paper.
I have the same machine, GBC H-300. I have it apart right now, and found the feed motor gear in pieces.
Motor Gear 18T 120v part #26700056
Mike Dettling
May 26, 2011 | Grilling
The machaine jammed and now will not work. i have taken it apart and removed all of the jammed material. when the machaine is turned on, it goes stright into paper jam mode. There is an electric humming...
the machine still thinks it is jammed. the humming is probably the motor trying to turn, it can not beause it still has a jam? . you may need to remove the power cord from the wall. remove the shredder fro the stand. flip it over. remove the bottom cover and manual trun the cutting heads to unstick them. you may need a tech
Oct 21, 2009 | Office Equipment & Supplies
My 5550 shredder is completely dead. Is there a manual/guide to removing the covers. How do I get to the power circuit?
Open the door and look up towards the bottom of the shredder head and find 4 Phillips screws to lift the cover off.
Oct 16, 2009 | Quartet gbc Shredmaster 5550X Confetti-Cut...
Gbc Combbind C110E Electric Binding System Logo
71 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
