Question about Saeco Incanto Classic Espresso Machine
SAECO INCANTO RAPID STEAM THE GEAR IN THE BACK IS STUCK AND WON'T MOVE INTO THE RIGHT POSITION TO PUT THE BREW UNIT BACK IN
WaltK
SOURCE: Saeco Vienna gear jammed
This has happened to me. If the problem is the brew group gear is in the wrong position, you can manipulate the brew group until it matches up with the drive gear in the machine. You'll know it matches if you can insert the brew group back in the machine full until it clicks.
Posted on Dec 08, 2007
dutchman05
  • 487 Answers
SOURCE: Our Saeco Incanto coffee machine
mmmm ormally with turning off and on it should reset itself.
Posted on Apr 16, 2008
mirran
  • 515 Answers
SOURCE: SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Posted on Jul 22, 2008
mirran
  • 515 Answers
SOURCE: Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Posted on Aug 15, 2008
mirran
  • 515 Answers
SOURCE: Saeco incanto rapid steam Model #SUP 021yr
Try to clean the brewing unit and make sure the filters is clean.
/Mirran
Posted on Aug 22, 2008
Saeco incanto del luxe coffee machine dumps coffee into waste drawer
Your brew unit may be set in the wrong position inside the machine if someone has had it out to clean or try to fix. The unit has two positions open and neutral when putting back into the machine it should be neutral. This is something I would try first. Now if it is in the open position you will need to reset it. Resetting is better explained on video so I have put a link for a Youtube video. This guy is great and guides you through step by step. Hope this works for you good luck. Please post and let me know.
Cheers
How to Remove Stuck Brew Unit Q
Feb 06, 2015 | Saeco Incanto Classic Espresso Machine
Saeco incanto classic
http://www.partsguru.com/SaecoIncantoClassic.html
Apr 24, 2014 | Saeco Incanto Classic Espresso Machine
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
I have an Incanto Rapid Steam, and I have had to take it in for the same problems and I am now so very frustrated cause they never fix it. I have spent almost as much on the repairs as the machine cost. It...
Either hte grind is not set correctly, the burrs are dull, espresso is being brewed in a cold cup, or the coffee is a little stale and the brew unit needs to be degreased.
Apr 13, 2010 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Deluxe brewunit jammed
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Mar 04, 2010 | Saeco INCANTO DELUXE Espresso Machine
Saeco S-class Incanto Sirius brew unit stuck
Try running the clean cycle again, that sometimes will help the machine to reset.
Sep 15, 2009 | Saeco Incanto Sirius Fully Automatic...
Saeco incanto deluxe gear or splinbe drive out 180 degrees.
Thats a tough one without seeing the unit, use the pic below to help align the unit.5101bd5.jpg
May 31, 2009 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
66 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
