P0440
SOURCE: i ran ouy of gas
You may have siezed the fuel pump. Fuel is used as a lubricant for the fuel pump. When you run out of gas and continue to crank the engine the fuel pump siezes from lack of lubrication. Sometimes you can get lucky by banging on the fuel tank while someone else turns the key to the run position (Not cranking the engine). keep slapping your hand against the fuel tank. This may free up the fuel pump. when you hear the fuel pump hum again then all is good. Also check your fuses, maybe you jsut burned up the fuel pump fuse.
