Question about Refrigerators
My Samsung RT22SC (da99-01391s) lower fridge door shelf has broken and I need to buy a new one. Please help me how and where I can buy it from! Thanks
  • 178 Answers
SOURCE: i need new parts for
www.partstoday.com they will need the model number to be able tro search for the parts, enjoy.
Posted on Apr 06, 2008
SOURCE: Looking for spare parts for
WE NEED SPARE PARTS FOR PARKING TICKET SPITTER OF FEDERAL APD TD-300
Posted on Sep 11, 2008
ghappliances
  • 126 Answers
SOURCE: Refrigerator Door Gasket Has Split
I FIND IT VERY STRANGE THAT THE ENTIRE DOOR NEEDS TO BE REPLACED IN THE EVENT THAT THE RUBBER IS FAULTY.I NO FOR A FACT THAT SOME SAMSUNG FRIDGE RUBBERS ARE QUITE HARD TO REPLACE AND THE QUICKEST SOLUTION FOR THE TECH IS TO REPLACE THE ENTIRE DOOR.TO ESTABLISH IF THE RUBBER IS REPLACABLE I SUGGEST YOU LIFT THE GASKET IN ONE CORNER AND LOOK FOR A GROOVE OR SCREWS.SOME RUBBERS ARE BASED ON A PUSH IN PULL OUT BASIS.IF YOU FIND IT HARD TO ESTABLISH WHICH IT IS I THINK ITS BEST YOU ASK SAMSUNG TO SEND YOU A MORE ADVANCED TECH TO ASSIST YOU IN THAT REGARD.ALSO YOU CAN VISIT SAMSUNG WEBSITE AND FIND A TECH NEAR YOU.
GOODLUCK.
MOHAMED
Posted on Sep 19, 2008
ghappliances
  • 126 Answers
SOURCE: i need a replacement door
FIRSTLY WHY DO YOU NEED TO REPLACE THE DOOR OF THE APPLIANCE.
MOAHMED
MNTECH
  • 1543 Answers
SOURCE: Punctured freezer wall in dormer fridge
Usually try not to even answer these questions because anything less than a FixYa drops my rating, so maybe don't bother rating, OK?
Yes, it's a goner. Repair would cost more than a new unit.
Posted on Oct 27, 2008
My Samsung Refrigerator side by side door ,,Model,,SRS583DHD,, left hand side door ice maker increases temp and not producing ice,,;-(,,Bot
Your description sounds like a loss of air flow problem. Check for overloading your freezer and fresh food side. In order for the freezer and fresh food side to work properly, the air vents need adequate room for air to circulate. I had a customer who completey filled the middle shelf with cardboard boxes and completely blocked air flow on the middle shelf The lower level near the evaporator was extremely cold and the upper area was room temperature in the freezer. Each shelf needs about an inch of room at the back and room between packaging to allow air to circulate.
Hope this helps
Dec 13, 2014 | Refrigerators
Fridge door shelf
Look up Sanyo Appliances on the internet. When you get to the Sanyo Appliance section, type in you product by name and number. When the item is found, look for replacement parts. Once you find the part you need, simply go from there.
Dec 19, 2013 | Sanyo Refrigerators
Side-door of fridge bottom shelf broken . How can I get a replacement?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Jul 29, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
What temperament should i put on my fridge?
Most fridge manufacturer's suggest 34 degrees F (but no lower) for the fresh food compartment, and 0 degrees F (lower is O.K.) for the freezer.
Measure temperature on the fresh food compartment by placing a thermometer in a 6 - 8 ounce glass filled with cold water. Place the glass with the thermometer on a shelf in the fridge. Wait about an hour or two (assuming the door stays shut) and check temperature. The water is to minimize changes shown on the thermometer when you open the fridge door.
I hope this helps & good luck! Please rate my reply. Thank you.
Mar 29, 2011 | Food Processors
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
I need shelves for the fridge and the plastic shelf at the bottom of the door is broken and needs replacing.
hi there......you havent stated the manufacturer of your fridge...however obtaining shelves for your fridge should be no problem..provided you have the model and serial number and if possible the product code.(a) contact your local your local domestic apliance repair/spares shop....(b) go online to the manufacturers web site...(c) go on line to google enter your fridge details this will provide you with information where to obtain your parts...
the door shelf may be a different issue...if the shelf is part of the door lining then you will need a relpacemant door
regards Sir Galahad
Aug 13, 2009 | Kenmore 91493 Stainless Steel Compact...
Freezer shelf doors
Check with the manufacturer, sounds like you have a factory defective freezer. they should fix it for you.
Jul 26, 2009 | LG LRTP1231W Top Freezer Refrigerator
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
