Question about Toshiba 32A33 32" TV
Remote control not working
I have a Toshiba TV and neither the television remote nor the Warner Cable remote control is working on the TV. The Cable remote control is working on the cable portion, but the TV itself does not respond to either remote to turn the TV on and off or volume. I've changed batteries on both remotes, just in case, but that is not the problem. I've rebooted the cable, but that is not the problem. I've unplugged the TV, but that is not the problem. Please help.
  • Toshiba Master
  • 13,433 Answers
Is the remote original and ment for the television? if not I would suggest a universal remote from any local retail shop to replace the non working remote.
Posted on Jan 02, 2009
    Genius:
  • 1,239 Answers
Hi
it lost all its programming if you still have the disc redownload the codes on to the remote if not go to logitechs web site and request another disc or download .or try universal remote
  • ABHISHEK.C
    ABHISHEK.C Jan 02, 2009
    id the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
    President:
  • 1,990 Answers
Welcome to Fixya! This sounds like the Recieving Mechanist inside the TV is Faulty and needs to be replaced by a Service Center.
  • Toshiba Master
  • 19,396 Answers
If no remote is working, it may be the IR board on tv not working. If you want to try an original replacement remote, you must give me the exact model of the TV.
  • Ginko
    Ginko Jan 02, 2009
    If you do not have an original remote with exact codes for this model, then buy an exact replacement for your TV, see here:Replacement Remotes
    1-800-Remotes
    If you already tried several universal remotes with right codes, and TV is still not working, The IR receiver on the TV is devective.
I need the tv remote codes for my toshiba tv model #24AF42. Lost the remote and need to use my Time Warner cable remote. Thanks
0028,0025,0029,0021. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 12, 2013 | Toshiba 24AF42 24" TV
Tip
I need a config. my remote control UEI By DirecTV
<span>If you are using the universal remote control provided by directv, try these codes 10054, 10030, 10171 <br />OR:<br /><b>Satellite TV Systems</b> Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 <b>Cable TV Systems</b> Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote "UEI" URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610 For the LTxxxxx series: You can use the codes listed under RCA, LG, Philips or Yamaha. <br />Thanks</span>
on May 07, 2011 | Televison & Video
My tv remote quit working. I would like the code for Daewoo TV, model No. DTQ-13P2FC to enter in another remote.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html Then select TW Cable remote model. Under Control a Device -- first select type of device (TV) Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
Jun 21, 2011 | Daewoo DTQ-13P2FC 13" TV
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
Cable box remote doesn't work when tv is turned on.
I am having this same problem with our Mitsubishi LCD Flat Panel TV, Model LT-46246 ans our Scientific Atlanta remote cable box, same model as yours. We cannot use the remote at all to change the channel. I called Mitsubishi and they said they have never heard of this. I find this incredibly hard to believe. Time Warner, our cable provider says that it is not the box because it works when not hooked up to the TV. What a pain. I would love to hear if anyone else is having this problem or has a fix for it.
Mar 25, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
Feb 27, 2009 | Panasonic Televison & Video
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Programming remote control to Cable TV Box
What you need to do is contact the manufacturer of either your remote control otherwise the manufacturer of the Time Warner [aka: cable providers some times also have the info on file for their customers] they store the code information within their internal systems for their customers such as yourself. Otherwise there is normally a paper insert with the remote control or the Time Warner that would list the info for select manufacturers on there. Toshiba has pretty universal IR signals/codes so you should be okay when trying to program in the codes. The manufacturers can also assist you through the steps--believe me it can get frustrating some times!
Jun 02, 2008 | Televison & Video
Codes to make my Time warner remote control the tv
Here's the list from Time Warner
http://www.timewarnercable.com/Carolinas/site.faqs/Equipmenta/Remotes/Digital-Remote-TV-Codes
Oct 26, 2007 | Toshiba 36A50 36" TV
Toshiba 32A33 32" TV Logo
410 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
