My tv's picture will fail while in operation. The picture will do a quick fade to black while in use, this can be corrected by turning the tv off and then back on again. However the length of time the
    Master:
  • 444 Answers
There is a (Problem) With one of the circut (Boards) In it. When they do that. Song & Dance. With you
Posted on Oct 25, 2012
  • 19 Answers
SOURCE: LG 42LG5 TURN ON TV PICTURE GOES BLACK
This could be 1 of a few things here. Without opening up your set and trying to look at voltages or indiciator lights I couldn't tell you exactly without some more info.
Without looking at it myself here are my thoughts and where I would first look at.
It may be a main board because:
1) Main board processes all your audio/video signals. Bad main board means bad video processing. Could do that. Especially if the main board is not sending the right signal or a bad signal to the rest of the boards so they don't do their jobs.
It may be a power supply because:
1) Power supply is well, the power supply. If it's sending inadaquete voltage to the main board you may not be recieving enough juice to keep that main board doing your video processing or further up the line keeping enough juice flowing to your TCon board to keep it telling things where to go and what to do. The power supply sends voltages to your Ballast board(controls your lights) and to your main board through which power is supplied to your TCon board via a LVDS line and a +12/+16V signals. If the power supply isn't pumping out enough juice to keep the TCon or Main Board running, it could be a problem. By the same token it could be that your P/S isn't sending power out to your ballast board.
It could be a TCon because:
1) If the TCon is bad, you won't get your pictures. This could be the TCon board itself or the LVDS cable from your TCon to your Main. However, with few exceptions, if it's a bad TCon you're looking at a total panel replacement.
It could be a ballast board because:
1) The Ballast Board controls the lighting behind the LCD screen. If this isn't working right you won't be seeing much of anything without that back lighting. If this is bad, it's a panel replacement. These are not field replaceable items by LG.
Based on the symptoms, without more data or a eyes-on view of it, I would say you're most likely looking at a Main Brd or PSU problem.
Posted on Feb 21, 2009
SOURCE: picture fades to black then reappears and repeats fades to black .
Maybe getting a solution to this problem doesn't matter to you any longer, but I purchased three of this same model at the same time and two of them have failed. One with picture and no sound; the other with sound and no picture. I'm just going to swap the components until I discover what the problem is. I'll post the results if I achieve success.
Posted on Apr 17, 2010
  • 4234 Answers
SOURCE: Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
Posted on May 04, 2010
pjbaldi
  • 8 Answers
SOURCE: dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Posted on Jun 02, 2010
SOURCE: vizio lcd sreen fading out.
Well time will tell if this is a true solution but I experienced the same issue. Originally I was able to get the TV to work by turning it off and back on.
After some research I notice the the Vizio FAQ mentions a similar issue for which the solution is to unplug the unit for 3min.
After calling Vizio, they suggested that under the menu option Setup, Picture, Advanced Video Features, I should try turning off Advanced Adaptive Luma and Backlight Control.
Vizio e500ib1 50"smart tv power on light then that goes out. has 5volt stand by only, there are voltage that come up but fade out. screen is black no sound. was working great perfect picture,
Do you have voltage (3.5V) on the PSON terminal when you push the start button on the TV...if you don't its the main board that has failed
Feb 09, 2018 | Vizio Televison & Video
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Televison & Video
How to fix a Sharp Aquos LC-40C32U Picture
No picture
Has anyone examined the filter caps in the sets power supply to see if they are puffed up?
4_4_2012_5_34_12_pm.jpgbad caps like these will have the top puffed up.
Apr 03, 2012 | Televison & Video
Panasonic plasma
If you open the back,look at the can shaped items.If any of them have the tops bulged out,they need to be replaced.This should solve your picture problem,unless there is something else wrong.What is happening,is they are heating up,and the picture goes out.I bet the longer you have the TV off,the longer it stays on?Hope this helps.Thank You very much! Tyler
Apr 06, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Picture fades to black then reappears and repeats fades to black .
Is the sound ok. Yust the Picture. If both dissapear replace power supply board. That is the main big board with the most heatsinks on it. Main power gos from a switch board to main power supply.
Nov 21, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
Picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Oct 11, 2006 | Mitsubishi CS-40507 40" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
