1996 Toyota RAV4 Logo
Posted on Jan 02, 2009
How do I change the light bulb on the gear selector on the
Automatic gear box? (1995 Rav 4, 2000cc engine).
John
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
742
Points
8
Its a fuse not the light bulb itself....
My 2010 Hyundai genesis gear selector has no lights, Where is the fuse?
If you have other lights, radio,instrument panel. Then the fuse is good. The A/C and the gear selector could have bad bulbs. You have to pop off the bezel and remove the screws to access the A/C. The gear selector, you have to pop off the boot(console type), pull it up, the bulb is on the drivers side.
Need to replace gear selector on golf automatic as it wont start cut out on me so was in gear have had it checked and it is the gear selector how do i fix it myself
Hi Gary, I may be wrong but I think the gear selector mechanism would not cause the vehicle to cut out? If a diagnostic scan has reported a fault with the selector mechanism it will be with alignment of the switching mechanism which allows start up only in park or neutral. If the starter turns the engine with the selector in either of those two positions (P or N) the problem is with the engine not the shifter. If the engine does not turn you may have two or more problems. Give more details and describe the events leading to the problem more clearly. Regards John
Notchy gear change on my daewoo lanos
Hi GJ, If the box is auto check the oil level in the box. You should do that with the park brake fully employed and the engine at idle speed with the selector in neutral. If the box is manual check the clutch adjustment, it should take about two and a half inches up from the floor. If the notchy change is only on one gear you may have a synchromesh cone problem and that means a box rebuild. Regards John
How do you know what gear the box is in when putting in an automatic turbo 700 gear box as to the gear stick in the car??
where the hole is for your say t bar selector on gear box, should be closest to the rear of your car so park is forward in the car means the gear box selector should be in opposite direction means closest to rear of car if having problems give me a call 0414946767 good luck.
'95 galant's automatic transmission was repaired but reverse won't apply and drive applies but won't change gears, what did I did wrong?
it also happened to my car before ..have your transmission computer box and selector sensor checked or diagnose. either of them are not working properly and needs to be replaced....
1helpful
2answers
HOW CAN I FIX A GEARBOX OF AN AUTOMATIC NISSAN B14
Auto boxes are best left to professionals but there are some things you can do 1) check that the selector rod from beneath the gear shift to the gear selector on the side of the gear box is correctly adjusted, 2) make sure that the transmission oil is at the right level, new oil can be added via the dip stick tube. If you are adventurous and are able to remove the gearbox pan you might be to see evidence of the gear box damage, metal shavings etc. If you can remove the gearbox you may be able to replace a sheared splined input shaft (indicated by a an engine that is running but that will simply not engage gear). Anything repairs beyond this should be left to an expert or simply replace the gearbox
1997 RAV 5th gear drops into neutral when gas throttle is released
If it only drops out on the over run only then its due to either the selector ball and spring on the selector shaft (spring gone weak )., or 5th gear scrinco worn out and needs replacing or the spigot shaft (input shaft) bearing worn allowing the shaft to move forward 3mm on over run, or a worn clutch plate can help cause the same problem.
THE ANSWER IS gear box out ,strip out and rebuild and both bearings on spigot shaft, and check clutch plate springs for wear.
LET ME KNOW HOW YOU GET ON . RON
1helpful
Desciption of the gear positions on the automatic gear shift
The gearbox normally shifts like this in "D":
1st gear to 2nd gear
2nd gear to 3rd gear
3rd gear to OverDrive
If you have the selector in "2", it will not make the final 2 shifts. "2" is nice for descending very steepo hills slowly, and also is nice to use coming down hills when it is icy/snowy, the engine will slow down in "2", and you will not have to depress the brake pedal.
Safety switch in transmission ?
Your Gear Position Sensor is failing. It's common on these models for this part to fail. It's common for the check engine light to also come on and store a code for this sensor.
http://repairpal.com/volvo-850-1995
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
