Question about BenQ PB7200 DLP Projector
There is a shadow on the right side of the light display
I'm having the same problem please let me know if you find out what the issue is.
Posted on Oct 31, 2012
I've had my projector for years now and worked perfectly. But now, there's a shadow on the right side of the screen. I cleaned the lenses and there's still a shadow. With my observations, it looks like...
Remove the bulb, look for any obstructions or damage. If you see none. Replace the bulb, usually replacing the bulb also replaces the lens, the frame around the bulb, and other components all at once making it an easy one stop fix for most visual display problems.
Jun 04, 2010 | InFocus ScreenPlay 4805 Multimedia...
A shadow on the right side of the screen from top to bottom
Something inside the unit is out of alignment in the light path
Apr 23, 2010 | InFocus ScreenPlay 4805 Multimedia...
Viewsonic VX2260wm has a shadow on the right side of the screen
install an AGP card in the AGP slot because internal display card of the motherboard does not support to high resolution because of insufficient memory . use 8X display card for the better result ..
Apr 18, 2010 | ViewSonic X Series VX2260wm 21.5"...
Slight shadow on right side of screen
this is image banding. the light tunnel needs to be adjusted, or replaced if it is collasped.
Apr 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
Symphonic 32'' lcd tv has shadow on right side of screen
The "shadow" indicates a failure either of the LCD controller, LCD connector, or in the worst case, the LCD itself. A loose connection between the LCD and the LCD controller can result in abnormal displays. Try tapping the back of the TV and check if the shadow can be affected. If it is affected, try cleaning the connector terminals with a soft-bristle brush and alcohol or lacquer thinner. If not, have it checked by a qualified technician to carry out the proper tests to determine which of the LCD controller or LCD the problem lies.
Dec 06, 2009 | Televison & Video
Shadow along side
does this shadow go from top to bottom on the left or right side app 1" to 2" wide ? if so your light engine needs to be replaced
Jan 17, 2009 | Toshiba 46HM95 46" HDTV
Shadow on right side of screen
check the connector of DMD module. Service all projector and reinstall.
Viren
Nov 18, 2007 | InFocus ScreenPlay 4805 Multimedia...
Infocus 70+
We have had similar issue w/ multiple LP70+ projectors. The units get to be 1-2 years old and suddenly the right vertical edge of the display is distorted. There is usually a shadowed vertical bar that clouds about 3-5% of the horizontal space from the right edge.
What's the cause?
Nov 13, 2007 | InFocus LP70+ Multimedia Projector
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
BenQ PB7200 DLP Projector Logo
50 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
