Question about Nikon Gruen Quartz-beautiful Vintage Wrist Watch W/liberty Coin Dial-rare
M.Z. Berger watch band
I need to remove links from the watch band, and the instructions that came with the watch do not apply to my band.
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 | Watches
How do I remove a link from the Stauer Colossus Hybrid Chronograph
Removing a link from the wrist band of the Stauer Colossus watch is a task that requires some mechanical talent. The links are held together with pins. These pins need to be pushed out. I strongly recommend the purchase of a "Watch Band Link Pin Remover" (got mine on eBay for $7). Prepared with this tool, the steps are as follows.
a) Separate the wrist band at the position where the strap and latch are held together. Careful! This pin is spring loaded.
b) The links that can be removed are marked with an arrow on the interior side. The pin should be removed in the direction indicated by the arrow.
c) With the previously mentioned tool you will be able to perform the hardest part, namely push out the pin by 3/16". In the image below note how the pushed out pin goes into the groove of the tool.
d) Use a small screwdriver or a punch with diameter of less than 0.07" (or 1.8 mm) in order to push out the pin completely (see second picture).
The push pin of the tool can be reversed which is helpful for re-assembly. I recommend smoothing the one end of the pin with a small file or sandpaper. This way the pin enters easily into the hole of the lower section. Else you run the danger of bending the link if the pin is not correctly positioned and you apply too much force.
Oct 24, 2012 | Watches
How do I take the links off an m.z berger
There are three links on either side of the closure mechanism
marked with an arrow. These are the ones to remove. If you only
need to remove one link, remove it from the six o'clock side of the band. If more than one, then try to balance, one from each side, etc.
The easiest way to remove individual links is with a "link remover"
tool of the sort used by jewelers. These are not expensive. The other way is to get a very small, slim diameter finishing nail and
position the sharp head of the nail in the slightly recessed hole of the link to be removed. The watch band should be perpendicular on a wooden table. Gently pound the nail downward with a hammer. If you're skillful, and lucky, you can get a 1/16" or more of the retaining pin to protrude from the other end. Now, use needle-nose pliers to gently twist and rock the protruding nub of the pin, and try to pull it out. Good luck with that.
You'll need to remove two retaining pins for each link, or consecutive run of links, that you're removing. Then reconnect
and line up the remaining links and (gently) insert and/or pound
one of the removed retaining pins back into the hole to keep the watch band assembly intact.
Again, good luck!
Feb 17, 2012 | Watches
Need to add links to a new Elgin watch band. The number on back of watch is SR626sw
That's the battery number for the watch also known as the #377. It's the most common watch battery in the world. Your model number is located at the bottom of the dial (face) below the six-o'clock position. You will need a 10 power jeweler's loupe or magnifying glass to see it and read it. Jot down the number and contact Elgin directly (MZ Berger Co,) for the extra links.
MZ Berger.
Jun 20, 2011 | Watches
My watch didn"t come w/
Hi
This might help you having a manual.
There are two options to get a manual:
1. thru mail, you need to provide the style number found in the back or beneath the number 6 on the watch.
2,. Thru phone, you need to provide the style number then the warranty and instruction will be mailed to you.  Also can give to you over the phone.
Customer care number:  718 472 7500
Customer care Fax Number: 718 472 7661
Address:
MZ Berger and Company
Attn:  Service Department
29 - 76 Northern Boulevard
Long Island City, NY 11101-2214
Also for more information you can click this link.
I hope this will help you.
Thank you for choosing Fixya.
Mar 09, 2011 | Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    Remove link form Relic Wrist band
    For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
    If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
    Hope this works for you!
    Feb 14, 2008 | Relic 0504648FA
    Watch Band Adjustment
    I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
    Tools:
    • 1 push pin like you use on bulletin boards with a plastic head
    • 1 small hammer like a tack hammer
    • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
    • 1 small block of wood
    Try to pick a well lit table in a room where you will not be interrupted.
    Procedure:
    1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
    2. Carefully line up the push pin point with the top of the pin.
    3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
    4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
    5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
    6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
    Nov 05, 2007 | Relic 0504648FA
    Link removal
    here are the steps SEARCH Watches Jewellery WATCHES JEWELLERY GIFT CENTER FEATURED ITEMS WATCH SPECIALS GIFT CERTIFICATES WHAT'S NEW HOME EN FRANCAIS ORDER TRACKING CURRENCY CONVERTER ABOUT US CONTACT US HELP How to Remove Watch Links The following method outlines how to remove most watch links. If you have any questions, please send us an email at Info@Webjeweller.com 1. Pin Type I 2. Leaf Spring Coupled Type 3.Single Screw Link Type 4.Snap Type 5.Bracelet Sizing Instructions 1. Pin Type I (Tools: Eyeleteer, Staking stand, Hammer or Pliers) Step 1. Set the watchband onto a staking stand or other appropriate holder. Step 2. Use an eyeleteer to push out the watchband connecting pin toward the arrow. If the pin is too tight, use a hammer to lightly tap out the pin. Step 3. Pull out the connecting pin with a pair of pliers. Step 4. The selected link can be disconnected from the adjoining link. 2. Leaf Spring Coupled Type (Tools: Tweezers or Pliers) Step 1. Use a pair of tweezers to push out the leaf spring of the link in the direction of the arrow. Step 2. Remove the leaf spring by using a pair of pliers. Step 3. Other types of leaf springs as illustrated above are also used in leaf Spring Coupled Type Watchbands. Step 4. Disconnect the link from its adjoining link. 3.Single Screw Link Type (Tools: 1-mm Screwdriver or Tweezers) Disassembly Step 1. Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side. Assembly Step 1. Reassembly is opposite of disassembly. Assemble the link, and turn the bracelet on its side. Insert the screw into the link either with a pair of tweezers or your fingers. The screw will only go into one side of the link. Step 2. With the bracelet still on its side, securely hold the bracelet between your fingers, and place the 1-mm screwdriver tip into the screw slot on the end of the screw. While using gentle downward pressure on the screwdriver, turn the screw in a clockwise direction until you feel the screw stop and the top of the screw is just below the edge of the edge of the bracelet. Do not apply more than gentle pressure on the screwdriver as it could cause the screwdriver tip to slip off the screw end, which may scratch the side of the bracelet. Step 3. Once the screw is screwed down in the link as fare as it will go, give the screwdriver one final"twist" to securely tighten the screw. Be careful not to use too much force as the screw head could become damaged. 4.Snap Type (Citizen Sizing Tool) Step 1. Remove the link pine in the direction of the arrow. Step 2. Grasp the band on either side of the link from which the pin was removed. Apply gentle upward pressure on the side nearest the case, while applying gentle downward pressure on the clasp side of the band. You will feel mechanism disengage. Step 3. While continuing to apply gentle pressure as outlined in the previous step, gently"rock" the band to completely release the mechainism. Step 4. After releasing the mechanism move the clasp side of the bracelet towards the case to dissemble the links. Step 5. Gently pull the links apart. Repeat the procedure for as many links as need removing. Reassembly is opposite of disassembly. 5.Bracelet Sizing Instructions (Tools: Citizen Blue Pin Pusher Link Joint Remover II or Tweezers) Link Components 1) Split Pipe -Two pieces, one at each end of the pin. Generally one split pipe will remain attached to pin during sizing. 2) Cylinder Link - Two pieces, one at each side of the bracelet link. 3) Link Pin - Connects link, cylinders and split pipes together. Step 1. Note the engraved arrow on the backside of the bracelet showing the direction in which the link pin should be pushed and lay the bracelet in the cradle as shown above. Align the pin of the pin pusher with the link pin, being careful to centre it. Once centreed?, apply slight pressure until you feel the pin begin to move and then turn fixture upright as shown in illustration . This slight pressure will keep the pin pusher in alignment with the link pin while the tool is being turned upright. Step 2. With the fixture standing in the upright position, apply even pressure to the pin pusher until the pin drops out. Step 3. Using the tweezers, set the pin/split pipe assembly and cylinder aside. If the cylinder comes off of the pin, reassemble the cylinder and pin. The split pipe for the link pin at this outside end is still on the pin and dose not need to be removed. To reassemble pin and cylinder, insert pin into the hole of the cylinder so that the split pipe rests in the recess of the cylinder. Set aside for use during reassembly of the bracelet. HOME TESTIMONIALS LEGAL NOTICE ORDER TRACKING F. A.Q'S REQUEST A WATCH ABOUT US CONTACT US En Fran?ais | Advertising Opportunities | Affiliate Program | Watches | Jewellery | Diamonds | Feedback | What's New Watch Search | Jewellery Search | Volume Pricing | Request a Watch | Specials | Privacy and Security | Site Map WebJeweller.com, Email: Info@WebJeweller.com Copyright © 1999-2006 webjeweller.com. All rights reserved.
    Aug 10, 2007 | Fossil AM3425 Wrist Watch
    Nikon Gruen Quartz-beautiful Vintage Wrist Watch W/liberty Coin Dial-rare Logo
    97 people viewed this question
    Top Nikon Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Nikon Watch Expert? Answer questions, earn points and help others
