Question about Insignia IS-LCDTV32 32 in. Television
When turn on tv it turns off
The tv is off and you turn it on ,as it comes on, it turns itself,this happens several time ,then it stays on ,its seems as if it has to warm up.has been happening for a couple months,what can I do ?i been leaving it on!!!Help is appreciated
    Top Expert:
  • Insignia Master
  • 14,553 Answers
This sounds like a very common issue.
If set is hard to turn on (takes several tries)but will eventually turn on here is what my guess would be.
Every set has a standby power supply that is running 7/24 if the set is plugged in and it supplies voltage to the remote circuit that turn on the main power supply for the tv and hence turn the set on.
This is an area where companies cut corners by using lower rated voltage caps. By this I mean Standby usually provides under 10 volts to trigger the set on----what they do is use filter caps rated at say 10 volts max in a circuit with 9 volts (example)=with the standby on all the time the filter caps (electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times and gradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of the capacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of them happen when set is a year or two old (no warranty) and all you have to do is look at the top to locate bad ones.
They are generally black or blue and round and vary in --they have two connections each--a + for positive and a - for negative--not unlike a battery which in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silver and metal looking with creases on top and if bad they will be puffed up on top---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10 vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with the same value capacitance (like the 220 uf) but go up to at least in this case (from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger so sometimes there is an issue of physical space for the replacement on the board to fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make 25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it may be the problem you have.
See attached photo of a typical cap and if you have questions or need advice let me know. when turn on tv it turns off - 10_26_2012_5_00_32_pm.jpg
Posted on Oct 26, 2012
4 Suggested Answers
guru_dev
  • 315 Answers
SOURCE: Volume goes up to 100 by itself
make sure there are no buttons sticking on the remote. open the remote and clean the buttons...
Posted on Apr 26, 2009
SOURCE: Insignia NS-LCD32 - 32" 720p Flat-Panel LCD Turns itself off, resets, then turns back on
It's haunted. You must appease the spirits with a virgin sacrifice.
Posted on Jan 15, 2010
  • 1779 Answers
SOURCE: T.V. all of a sudden
The only thing you can do is replace the Main Board, which will be about 1/2 of what you paid for the set. I don't recommend it.
Posted on Mar 20, 2011
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Once the TV is turned on, the sound and picture disappears and replaced by a blank screen. If one turns it off again and on imediately the picture and sound returns. This may happen several times in a row,...
Could be ethier one the dish box or the tv itself have cold solders joints on the FBT-Flyback transformer.That the big black block of plastic with a red wire with a black cap hook to the CRT-(tv tube).Call ur tv Dish box customer service,get a replacement box.See, if this will solved ur tv problems.If not,than the tv must be taken aparts and must have tools like a soldering iron,a roll of solders,also must know basic soldering.Resolders all the coldsolders joints on the FBT for a better High voltages contact to the CRT-(tv tube).This problems,will be solved.
Dec 03, 2010 | Philips Magnavox 27MS343S 27" TV
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Recently our tv has been shutting off. We have
Seems to be problem with Vizio Tv's.. mine does the same thing now. it turns off an on for about 20 times before it will turn on and stay on..
May 25, 2010 | Vizio L32 32 in. LCD HDTV
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Insignia IS-LCDTV32 32 in. Television Logo
27 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
