Question about Amana ALE331RAW Gas Dryer
Won't spin bad smell dryer
2 Suggested Answers
masterrrex
  • 45 Answers
SOURCE: AMANA HEAVY DUTY DRYER model #NDG2335AWW
m ost likely one of the rear drum support rollers is bad. the part number is 37001042.
Posted on Mar 21, 2012
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
Won't spin
The start relay on the motor is bad and you will need to replace the motor. The relay is not sold separate. Here is the motor you need to order.
Oct 30, 2012 | Frigidaire AEQ7000EG Affinity Series...
Dryer has power but doesn't spin or heat up
Check to see if the door switch "clicks" when you push and release it. If the switch is bad, the dryer won't run. Here is the part in case you need it.
Oct 30, 2012 | Frigidaire FGQ332ES Gas Dryer
Sears laundry center 92702 burning smell and won't drain spin out
If the motor is running and it won't drain or spin, then the motor coupler has failed and needs replacing. Here is a link to the part.
Here is a video to show you how to replace the coupler. If you could post the model number that is located on the unit I can get you the service manual to help you a little better.
Oct 18, 2012 | Sears 24 in. Electric Laundry Center with...
Mar 21, 2012 | Amana NDG7800AW Gas Dryer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Won't spin
If this is an older dryer...a few yrs old. It's probably a loose or broken belt' Or bad motor.
Hope this helps you
Please find time to rate me.
Jun 28, 2011 | Frigidaire Dryers
My LG DLE8377WM dryer stop spinning. Turns on fine, smells as though heater element turns on but the tub won't spin. Can hear what sounds like a motor trying to turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 25, 2011 | LG DLE8377 Dryer
Amana ALE331RAW Gas Dryer Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
