Question about Dell Inspiron 8000 Notebook
Cant get enternet explorer on my dell inspiron 8000
Shows connection but wont let log on
    Problem Solver:
  • 18 Answers
Check in internet explorer preferences if offline mode is selected.
Posted on Oct 25, 2012
  • 38 Answers
SOURCE: Dell Inspiron laptop will turn on but wont take me to log in screen
Shut down the computer and then hold Fn key and then press the power buttong which will take you to Pre Boot Assesment test so let the test run and if hard drive is failing it will give you an error.If you want to do extended test then once this PSA test is finished it will ask you wether you want to remaining memory test just say yes and after that run the extended test which test the computer components extensivly and by that you can make sure wether hard drive is fine or not.If everything passes then reisntall Operating system or if you want to try to repair then boot from vista dvd (if vista) and then choose option repair.Let me know if further help needed
Posted on Nov 16, 2008
  • 4 Answers
SOURCE: dell inspiron 8000 without operating system
First, if you are still running Vista on your desktop then you will need to buy a license for the laptop. Does the laptop have a WinXP on it now? If so, go here http://www.microsoft.com/windows/windows-vista/get/upgrade-advisor.aspx and run the Vista Upgrade Advisor. If not, determine the hardware specifications of your laptop and go here http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx Compare your laptops specs to those listed for the version of Vista you wish to install.
Posted on May 28, 2009
  • 3278 Answers
SOURCE: My Dell Inspiron 1525 wont load up
I'd suggest first removing your memory modules and reinsert one at a time.
But, I think your operating system is compromised, due to Spyware, etc.
Since your system won't boot in Safe Mode, your only other option is to repair or reinstall your operating system.
Hope this helps.
Posted on Aug 31, 2009
  • 14 Answers
SOURCE: dell inspiron 5150 laptop, reset admin. password.
Restart your laptop and keep tapping F8 key the moment you see something on the screen. You will get a black screen with some options written in white. Select the option Safe mode and then you can create a new user with admin rights. Or else at the windows login screen press and hold ctrl and alt key and tap delete key twice and then it will take you to a login screen. Dont put any password there just hit enter. And you will be able to login with admin rights.
Thanks
Deepak
Posted on Oct 28, 2009
jeyem
  • 65 Answers
SOURCE: internet explorer wont open on my dell inspiron
try going to safemode w/ networking.
if you're using windows XP try this
to access that mode, shutdown the computer completely and after 20 secs turn in on again, as soon as you see the dell screen immediately strike F8 key continuously, if that is successful you should be at the advance menu options. use your arrow keys to choose and highlight safemode w/ networking and hit enter. if you see your operating system after just hit enter again.
once at safemode try to pull up internet explorer if still this doesnt work, go to the contol panel click internet options if your in classic view but if not click network connections first then click internet options. click the advance tab, that should be at the least right hand side, click reset which is under restore advance settings.
if your using IE8 at windows XP operating system, try uninstalling the IE8, to do that try the instructions below.
click start
click control panel
click add/remove program
find and click the IE8 then click uninstall or remove
then restart the computer
if still doesnt work try to install a different browser like mozilla firefox, google chrome or maxthon
and if still doesnt work then try to reinstall the operating system back to factory settings.
i hope this helps
Pls rate my resolution thanks!!
Posted on Mar 05, 2010
Does the Dell inspiron 8000 have a built-in webcam?
Here is the specs and it doesn't say anything about webcam.
SUMMARY corner_ffffff-fff0cc_13x13.gifDell Inspiron 8000
Pentium III-900/700 CPU,
128MB of SDRAM,
256KB L2 cache,
Windows Millennium Edition,
15-inch active-matrix screen,
NVidia GeForce2 Go graphics chip with 16MB of SDRAM,
20GB hard drive,
8X DVD-ROM drive,
built-in network adapter,
V.90 modem,
touchpad and eraserhead pointing devices,
9.2-pound weight (with AC adapter and phone cord),
Aug 24, 2010 | Dell Inspiron 8000 Notebook
Dell inspiron 8000 wont run
Have you tried new memory? or reseating the ones you already have
Nov 26, 2009 | Dell Inspiron 8000 Notebook
Problem in os
Try starting explorer by going to file\new task (run..) and typing explorer.
If it doesnt work, just type msconfig on the same box and go to startup tab, leaving everything unmarked, just reboot your pc and problem should be solved
Jun 21, 2009 | Dell Inspiron 1420 Laptop
Need password for Inspiron 8000 service code *******-595b
if you are getting a hard drive password prompt ***********-595B then the fix is simple enough, replace the hard drive. The password prompt is supposed to be the HDD serial number, but since it is showing as all astricks, then the firmware of the drive is bad and a replacement drive is the fix.
Mar 24, 2009 | Dell Computers & Internet
I have a dell inspiron 1000 the internet used to work fine on wireless and ethernet it started running slow so i had it cleaned out now it wont connect to the enternet at all. when i click on the view...
Check to see if your Dell is fragmented.
Go to My Computer,
RH click on it,
Go to manage.
Click on disk defragmentor,
If you see alot of red in the chart it is fragmented.
Click the Defragment button and walk away from the computer for at least 30 minutes.
It will max out the cpu and you will not be able to do anything on it.
If it is a laptop make sure the power is connected.
If this does not work,
make sure that the wireless and the wired connection are not running at the same time.
This will slow down the computer.
Mar 11, 2009 | Dell Inspiron 6000 Notebook
Since the laptop is in the 13 day exchange period i would suggest you go for a replacement PC cuz the OS is corrupt maybe cuz of a bad Hard Drive or bad installation... you could go ahead with a reinstall or use PC restore but then again it might be an continious issue later as well...
Feb 12, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 8000 - USB2 Universal Host controller
you can plug your pen drive backside. if its cant work your computer speed is slow.
Sep 20, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Enternet exsplorer
i think you just need a newer version of explorer.
Apr 30, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Cannot access my yahoo mail account
Try clicking on the refresh button each time or next time it happens.. If you are you are using Enternet Explorer Version 7.0 5730.11. Then your likely problems are there. I found it happening to me a bit but found it come right when I hit the green arrow tab(refresh button) I could see the page again. I think if I remember rightly at some stage Microsoft said it was a fault of the site you are perusing. Mainly if they had not updated to the new Explorer. That could be why you were experiencing the difficulties in viewing the page. You changed from one broadband to another that dont support the lattest software.
Sep 05, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 8000 Notebook Logo
62 people viewed this question
Alun Cox
