Question about Pioneer CU-VSX158 Remote Control
How do i reprogram my cu-vsx158 after changing the batteries
After i changed the batteries the remote will only control the volumn.the power button does't work nor the other controls which worked before the batteries changed
swami nathan
  • 208 Answers
SOURCE: pioneer 530H DVD recorder
You said that you have changed the batteries.
While you're checking the batteries, make sure that the contacts for the batteries aren't corroded or bent. You can clean them with a pencil eraser followed by a nail file. If necessary, gently bend them back to their correct position.
Try these too,
  • Go up to the receiver and try changing the channels without using the Remote Control.
  • Refer to the Remote Control setup instructions, and make sure you have the correct codes programmed for your equipment.
  • Make sure nothing is blocking the front of the receiver (e.g., furniture).
  • Make sure you are operating the Remote Control within 20 feet of the receiver.
If all the above doesnt work,
Then
Either the remote or the receptor on the device is not functioning.
1. Use an Infrared Sensor Card to see if the remote is sending a signal.
2. If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
You can visit this site for further support, www.pioneerelectronics.com/PUSA/Support/CarAudioVideo
Hope my info solves your problem,
Thanx for using fixya....
Posted on Oct 01, 2008
Whitenoize
  • 11 Answers
SOURCE: Remote for my Pioneer audio-visual receiver just quit working.
Well, there aren't many options for fixing a remote control.
If would not be cost efficient to do so either.
I personally do not bother with the factory remotes.
I would recommend you consider a Logitech Harmony remote as a replacement.
These are some of the easiest remotes to setup and use and start as low as $55 on the internet.
Hope this helps...
Posted on Mar 23, 2009
  • 5 Answers
SOURCE: Pioneer Elite VSX-92txh - panel buttons stop wkg won't pwr off
There is a fix for this problem. Check out this info.
http://www.curtpalme.com/forum/viewtopic.php?t=19315
Posted on Dec 29, 2009
  • 362 Answers
SOURCE: The volume control button on
most used button on your controller could be a victim of grime carefully take apart the controller and gently clean the pickups with an eraser or light alcohol based cleaning solution a little goes along way also flip the button pad and inspect for dirt ok soft drinks are often the culprit hope this helps
Posted on Nov 17, 2010
Testimonial: "Thank you - this helpful tip seems to have solved the problem."
  • 2385 Answers
SOURCE: The remote control will not change the channel. It
the remote gone faulty needs repair, change the batteries and try otherwise replacement/repair recommended
Posted on Nov 25, 2010
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
Bought a new RCA 37LA30RQ. Remote worked for the first 2 days we had it. Now, when I press power (or an other button), the power button on the remote quickly flashes and nothing turns on. Changed the...
Im pretty sure all you need to do at this point is reprogram the remote. If you dont have the codes go to the RCA website. They normally loose the codes when the batteries die and you have to change them out and re-program it. hope this helps!
Sep 09, 2011 | RCA Universal Remote Control
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Just changed batteries in universal remote don't know the code to reprogram the remote the inside says it's an rcr3273 with the numbers of r55lb5711p
Make sure the device is on. Hold down the tv (or whichever device your trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly letting it flash until the device turns off. Then press the stop button...and it is programmed.
Aug 19, 2008 | RCA Universal Remote Control
Tivo DirectTV remote problem
I have a Tivo black peanut remote. Can this remote be reprogrammed to power a different receiver?
Dec 07, 2007 | Tivo DirectTV Remote Remote Control
Dynamic entertainment system mx3000
what kind of battery does this thing take?
Nov 06, 2007 | Universal Remote Control MX-3000 LCD...
Televison & Video Logo
23 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
