Question about Pioneer CDJ-850 CD PLAYER
My pioneer only ejecting disc on not loading
Not loading disc ejecting it
4 Suggested Answers
SOURCE: The CDJ won't load the disc!!!
You have to get it repaired,no quick fix im afraid.
email: info@audiovisualservices.info for all dj equipment repairs.
Thanks.
Posted on Oct 02, 2008
Nic61
  • 1073 Answers
SOURCE: Need service manual for Pioneer XV HTD5
http://www.service.pioneer-eur.com/peeservice/InstrManuals.nsf/0/817C627E26301ED841256BE300511FA3/$File/XRB3016_XV-HTD50.pdf
The manaula as asked
Good luck
Nic
RATE me pls:)
Posted on Mar 17, 2009
  • 661 Answers
SOURCE: Pioneer DVD 717 - Not
Hi msaslloyd ,
This could be because of a damaged lens , where the dvd player tries to recognize the disc but is unable to do so and then either sends the disc back i.e. the tray opens up or the message no disc loaded is displayed.
I suggest you to :-
  1. Clean the lens with a lens cleaner available in the market and load any disc in the player to check if it's working fine.
  2. Get the lens replaced from the market and the problem should be solved.
Hope this helps ..:)
Posted on May 10, 2011
Testimonial: "much appreciated. will follow advice and am crossing fingers!"
How to eject a CD from seen pioneer 2600ui
If the DISC eject button does not work, insert the pin into the disc force eject hole to eject the disc. For details, see "Main Unit Front Panel" in the operating instructions.
Jun 13, 2016 | Pioneer Car Audio & Video
Pioneer cdj 400 unit turns on, takes cd, cd spins and then just ejects it.
There are two reasons for this fault. The first one is with its disc loading mechanism. If the mechanism do not place the disc properly on to the reading chasis, this fault can be. It will spin for some time and will ejected automatically
The second one is with its optical pickup unit. If optical pickup unit do not read the disc; due to some fault to it [dust or dirt over the optical lens]. But in this case, there will be only "No Disc" display will be there. No automatic ejection will take place.
With your player, the first sated might be the case. The disc loading mechanism might need replacement.
May 29, 2012 | Pioneer Audio Players & Recorders
Pioneer DVD 717 - Not Loading Discs Whenever I load a disc, the player spins the disc for a moment before slowing down. to a stop. It repeats this around four times in succession before it then opens...
Hi msaslloyd ,
I suggest you to :-
May 10, 2011 | Pioneer DV-717 DVD Player
How do I instert a CD into my pioneer deh-p6200 car radio?
Slide the door open (1/2 gray 1/2 silver door) on the disc changer, inside is a push button that ejects the 6 disc cartridge. Load and unload cd's into it.
Oct 05, 2009 | Pioneer CDX-P1280 12-Disc CD Changer
Pioneer dvr3100
hi.. the problem is not with ur DVD-RW disc... Its in ur device.Might be the device is unable to read the disc.. so better try to clean up the lense of ur device with the help of lense cleaner... it will remove of the dust so that it will be able to read the disc...
thank u
Feb 01, 2009 | Pioneer DVR 105 DVD-RW Burner
Thanks.
Aug 23, 2008 | Pioneer CDJ-800 Turntable
I have a 6 disc pioneer CD player that will not play or eject the case of CD's? It trys but nothing happens.
This sometimes happens when you put two disc's in one tray. If it's not locked in the loaded position then you can take a thin piece of plastic (as thin as a credit card but longer, five inches or so) or the equivilant (like that impossible to open without cutting yourself plastic packaging) and slide it underneath the 6 disc cartridge. You need to work it in and out, eventually you will hit the release mechanisim.
If a disc is loaded then it won't work and you need to dissasemble the changer and manually retract the disc.
Jul 17, 2008 | Pioneer Car Audio & Video
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Pioneer CDJ-850 CD PLAYER Logo
27 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
