Question about Air Tools & Compressors
I have an Atlas 185 Jd diesel compressor. The engine starts fine, but when the switch goes back to run mode, the engine dies. All fluid levels are good.
ollie reece
  • 1167 Answers
SOURCE: I have a Sullair 185 air compressor. The engine
your not return balve is stuck open or your valves are sticking the pressure from the tank is going back to the pump so when the compressor goes on the compress stroke its very hard as it has to open the valve with pressure behind it its hard to explaing buddy but on the tank you wil see anon return valve from the pump unscrew it and inside is a rubber with a spring turn the rubber around and try this if doesnt work you need to inspect the valves (if sticking) good luck
Posted on Sep 02, 2009
  • 89 Answers
SOURCE: 1989 Ingersoll-Rand 185 cfm air compressor will not build up air
ITS A POSSIBILITY AND YOU BETTER HOPE ITS NOT SPINNING BECAUSE THE SCREW COMPRESSOR IS LOCKED UP. CHECK THE OIL LEVEL IN THE SUMP AND SEE IF THE ROTOR WILL TURN WHEN NOT RUNNING. TYPICALLY THE DIESEL ENGINE WILL TURN HIGHER RPMS WHEN IT HAS NO DRAG ( NO COMPRESSOR HOOKED UP ). YOU CAN GET THE PARTS FROM INGERSOL RAND OR ANY RENTAL YARD - UNITED, PENSKE, SUNBELT, ETC. THEIR MECHANIC SHOPS ARE USUALLY FOR HIRE AND CAN EVEN INSTALL IT FOR A CHARGE. ALSO MAKE SURE NOTHING BUILT A NEST IN THERE. IF YOU REMOVE THE SCREW, MAKE SURE AND WATCH FOR SHIMS. THOSE SHAFTS NEED TO LINED UP PERFECT TO REDUCE VIBRATION. GOOD LUCK
Posted on Apr 07, 2009
compman66
  • 169 Answers
SOURCE: 1989 Ingersoll Rand 185 diesel compressor shuts down under load
most have safety shut downs built in, on the compressor side you will have a high discharge temp shut down, usually set to shut down @ 230 degrees F. normal temp should be @ 180F if it is running hot first check oil level on the compressor, and that the radiator is clean. some machines will have a thermostat that will only allow oil flow to go to the radiator after it comes up to about 150 degrees F. you really need to have a manual on the machine to see what other safety's it may have on the compressor and engine side as well.
Posted on Jan 09, 2010
Testimonial: "Thank you very much for responding. It was a little low on coolant. The comp. oil level was fine. I changed the fuel filter and the prob is gone"
  • 243 Answers
SOURCE: my tow behind air compressor ingersoll rand 185
press load button or toggle switch
Posted on Feb 08, 2010
  • 18 Answers
SOURCE: Sullair 185 screw compressor
The sullair 185 has a low oil pressure override button that you have to hold in while starting. after the oil pressure builds up(takes about ten seconds) you can release the button and the machine should continue to run.
Posted on Jul 10, 2010
What does a JDEC warning mean on my XAS 375 Atlas Copco
Atlas Copco has used John Deer Diesel engines in the past, that could be a warning or code concerning the engine since it starts with JD.
Mar 09, 2018 | Air Tools & Compressors
I have a JD 997. It will mow fine for 15 minutes, then all of a sudden it shuts off like you turned the key off. I wait a minute and it starts right up
more information as to engine type --petrol or diesel
I would start at the replacement fuel filter as it may not be compatible and blocking fuel flow which is what is indicated
restricted fuel flow
Apr 25, 2017 | John Deere Garden
My 1988 F350 diesel starts and runs fine, but when put into any gear the engine dies, it is and automatic.If you hold the key toward the starting mode 1/8 inch ,it works fine.
it sounds like your ignition switch is bad have it replaced thats what sends the signal to starter as well as rest of engine to run or not run
Nov 23, 2010 | 1988 Ford F 350
I have a sullair 185 engine dies and light blinks one and says compressor over heating what causes the compressor to overheat
Hi, my name is John. Welcome to FixYa. Low oil level, and poor air circulation. Thanks for choosing FixYa....John
Nov 22, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
Feb 25, 2010 | Atlas Translator Atlas Copco Air Hammer...
Feb 19, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
Jan 08, 2010 | Air Tools & Compressors
My 1998 atlas copco xas 97 185cfm deutch diesel shuts down when i open full air
Check the Deutch diesel engine controls. Normally with
the compressor at full open, engine must continously run, sionce this is the point where the engine is not
heavy loaded. Check the injection pump as well as engine speed control and the air filter.
Nov 04, 2009 | Air Tools & Compressors
Apr 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
616 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
