Question about Sharp R-1460 Microwave Oven
How do I increase the intensity of the green in the display on my Sharp Carousel R-1460A microwave oven?
The green display numerals and letters show up very weakly against the black background. the unit was manufactured in February 1997.
  • Sharp Master
  • 9,098 Answers
This model does not have a brightness adjustment for the VFD display.
It may be a weak VFD tube due to aging or it may be that the rear of the display window and front of the display glass are very dusty.
Sometimes you can clean it inside to brighten it up.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Some connectors have a lock.
positivelock.jpgIf that cleaning didn't help, then you have a weak VFD.
We can replace yours for $74.95. Details are here.
Posted on Oct 26, 2012
MicrowaveSvc
  • 9098 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
tiway1
  • 100 Answers
SOURCE: i have a sharp carousel
The tray is Sharp part # NTNT-A011WRF0 or NTNT-A034WRE0. (Same part, just different numbers).
Here's the link to where you can find it...
www.microwaveglasstrays.com
Posted on Jun 30, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My Sharp Carousel R-510HW 1200
On these models, the LCD is connected to the main control board via a rubber connector known as a "zebra strip".
Sometimes the connections can get contaminated.
One can take the control board off and clean the contact surfaces of the board, the edges of the zebra strip and the connection side of the LCD glass with high-grade isopropyl alcohol.
See drawing below.
If you don't want to tackle this, we do it for $39.95 for customers nationwide.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 08, 2008
tiway1
  • 100 Answers
SOURCE: Sharp Carousel Microwave oven
Assuming the unit works ok other than the display, you have a problem common to many Sharp models.
Check with www.microwavedisplay.com - lots of info on this issue and they offer a repair service for the boards at a very reasonable price.
Posted on Jul 11, 2008
SOURCE: Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Posted on Dec 14, 2009
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
How do i remove the display on a sharp carousel microwave in order to get roaches out?
Take of the main cover and turn upside down and give it a good shake to clean out.
Jan 09, 2015 | Sharp Carousel R530EST Microwave Oven
I have a sharp r-1460a Carousel Oven...outlet is good but there is no power...not even the clock. I want to replace the fuse first ...I have the control panel loose. where do I find the fuse?
you must be very careful as the result could end up with trip to hospital , 1) the main fuse should be fitted within the plug , 2) there are 2 other quick break fuses sited next to the transformer ,but please be very careful , if you don't know then get some one who does ,
Oct 20, 2011 | Microwave Ovens
My Sharp Microwave R-1460A make load noises when turntable is on. Noises stop when turntable is turned off.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | Sharp R-1460 Microwave Oven
Sharp R-1460A Timer counts down very rapidily and no heat
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Dec 12, 2009 | Sharp R-1480 Microwave Oven
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Melted carousel in microwave / bad smell
For the smell, do a Google search for "smell microwave" or "odor microwave" for many great tips.
If you need a new turntable support, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
It's part # FROLPB017MRK0
Nov 03, 2007 | Microwave Ovens
Microwave Ovens Logo
204 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
