Most likely one of your component cables is loose or unplugged. this will stop one of the colors from coming through, thus throwning off your color. you need to check your red, blue, and green cables.
sounds like your print head needs cleaning
make sure you have ink in the cartridges
open up your printer properties and look for a maintenance section and choose head cleaning
print a test page to comfirm that the head is clean
some printers need a deep cleaning
when the test page comes out without any imperfections, it should print fine.
Ur tv look dull in pictures?Ur tv might need it CRT tube coolant replacement.Tries websites like Tvrepairworld.com,Tvrepairkit.com to buy a coolant kit to replaced CRT tube coolant replacement.
Just make sure the right colors are in the right place, photo magenta is not interchangeable regular magenta. Also run the nozzle check to make sure all colors print, if after 2 deep clean cycles you don't have all colors you may need a new printhead.
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
