Question about Logitech X-540 Computer Speakers
No sound from computer speakers
I have a logitech thx z-5300 speaker system. all i get is hiss and static after pluggin them up to my computer. they worked fine before then i unhooked them but now i have them hooked back up to the same computer and they dont play anything. i hear something like noise/artifacts but no vocals or music. what gives?
    President:
  • 8,637 Answers
Make sure that you have the speaker plugged into the GREEN jack on the back of the computer or sound card. If they are not color coded then make sure it is plugged into the speaker out. Pink is for the mike and Blue is or plain is for input. You probably already know this but sometimes it helps to know if your not sure. Hope this is of some help. Bud
Posted on Jan 09, 2009
Channels for my z-5300 logitech not working
If you are having problems with you sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 21, 2011 | Logitech Z-5300 Computer Speakers
We connected our z 5300 speaker to a new computer. and get no. sound. Is there a driver that needs to be installed. the last computer no longer works.
Did you open your speaker ICON and check to see that you don't have the audio muted? I have seen a lot of customers complain that their NEW speakers don't work but they have their audio set to mute.
Mar 06, 2011 | Logitech Z-5300 Computer Speakers
I can only listen sound from the 2 front speakers while i have logitech x-530 5.1. My mobo has 3 colours at audio(pink.greeen.blue) and my speakers have green.pink.black. I only plugged green tho. Can i...
plug them all in pink/pink green/green blue/black
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Dec 28, 2010 | Logitech X-530 Computer Speakers
I need drivers for my Z-5300 Logitech Speaker System
Sir,
check this site for download all logitech speaker driver. wareseeker.com/free-logitech-z-2300/
Thanks Good Luck
Sep 12, 2009 | Logitech Z-5300E (970102-1403) Computer...
Hi I have a problem with my z-5300 logitech surround sound speakers. i just updated my pc to windows vista and when it all restarted i cant get my sound devices to work, it says i have no audio devices...
pls insert your motherboard cd in you computer and reinstall sound diver and after restart your pc .......and all pins are proper connect in computer .........speaker is working ..........ok
Mar 30, 2009 | Logitech Z-5300 Computer Speakers
Z-5300 speaker no sound
You need to install the sound drivers for your PC. go to the manufacturers website, (ex.www.hp.com) and go to the support section, sometimes called downloads also. It will prompt you for your model of PC and what Operating System ( XP,Vista,etc..) and then it will list the drivers that are available. you should update anything in "DeviceManager" that has anything except the "+" sign beside it.
Service manual logitech z 5300
Enclosed Image is from Z-5300 Manuel
Nov 28, 2008 | Logitech Z-5300 Computer Speakers
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Logitech X-540 Computer Speakers Logo
192 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
