Question about Zenith IQB36B42W TV
Zenith 27" tv
Dark picture cannot be brightened/lightened with controls available. occasionally there is a red "shadow" that also I cannot eliminate.
with the advent of digital requirements, I am guessing it will not be worth having this unit serviced. wonder if there is anything to do to fix the above, inhouse??
5 Suggested Answers
MikeNJ1964
  • 398 Answers
SOURCE: Zenith A27A23W 27 Capacitor CX 3231 blew up
The little blue caps that burn up are 560pF 2KV caps
Posted on Jun 26, 2007
SOURCE: Zenith Sentry 2
Mexican captions
Posted on Mar 13, 2008
Rifaa
  • 99 Answers
SOURCE: Dark picture after storm.
Dark picture? hmm.
meaning there is no brightness variation, assuming this is the fault I think U might be having low screen voltage. Check for high value ( around 2W) resistor, preferably from 100K to 680K on the "C" board or neck board. Post back
Rifaa
Posted on Nov 12, 2008
joboo1
  • 257 Answers
SOURCE: I think my picture tube is going out on my Zenith System 3 Tv
Hi, Sorry it took someone so long to get back to you, but nobody likes to give bad news. This tv has a 1.7R tube with 530 resolution and an NTSC tuner which means it is analog and with the new change this month you would need a converter box anyway unless you have cable or satellite. Because of this particular tube and the labor to change it, it would indeed more expensive to replace it than buy a new one. Best of luck to you!
Posted on Feb 05, 2009
1995 27" zenith tv picture dark with red glare won't adjust
THE TUBE IS CARBONIZED -IF YOU HAVE A TECHNICAL KNOWS
PUT 9V CA or CC IN FILAMENT AND A LAMP MAX 15WATTS IN SERIE WITH ANODE AND RED GREEN BLUE CATHODE (ONE AT TIME) -OFF FILAMENT AND YOULL SEE SPARKS INSIDE THE TUBE WHEN DESCABONIZE. REPEAT AT LEAST 3 TIMES
Sep 25, 2013 | Zenith B27A11Z 27" TV
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Aug 12, 2007 | Zenith C27A24T 27" TV
Dark picture..not bright picture
The whole point of a webcam is to be able to see the person you are speaking with, and let them see you. When the image broadcasted by your camera is too dark, the person on the viewing end won't see anything but shadows and dark shapes. Learn how to brighten your webcam image so the people you chat with can see you.
Place lamps behind and to the side of the webcam. This casts a light on your face, but the lamps will not wash out the image because they are behind the camera. Turn off lamps that are behind you. You have trouble seeing things when you are looking in the direction of the sun or a light bulb. Your webcam has the same problems. Don't make it stare at a bright light. Open up a white screen on your computer to brighten your face. The white screen will create the brightest possible light from you computer screen and help lighten your webcam image. This option is best when lamps are not available. Open up an empty tab in your Internet browser, or a blank Notepad document, and expand it to the full of your screen. Adjust your webcam settings. The settings available to you will depend on your webcam, but many of them offer a "Brightness" setting that you can increase to lighten your webcam. Open the program that came with your webcam, then look for a "Settings" or "Options" menu. Increase the "Brightness" setting until it has lightened your webcam enough.
b>
Feb 08, 2013 | Gear Head Computers & Internet
Zenith TV has me seeing red.
The red gun in the picture tube itself is shorted on. You will have to replace the picture tube itself to fix the problem. Probably want to just buy a new set. Sorry!
Mar 16, 2010 | Zenith B25A10Z 25" TV
Dark screen
the sound is locked off the TV good picture
Feb 20, 2009 | JVC AV-27320 27" TV
Dark picture? hmm.
Rifaa
Nov 03, 2008 | Zenith C27A24T 27" TV
GE Television Dark Shadows
If you are comfortable working inside the set, I can suggest the following:
1) Open up the back and locate the flyback transformer (part with large red wire coming out the top). There should be 2 adjustment posts on the back of it.
2) adjust the top one slightly clockwise as you are facing ht back of the TV. This should cause the overall picture to brighten. Don't turn it too much as you will then see the "retrace" lines.
3) Adjust the lower one to focus the picture.
That should help a bit. If not, then the picture tube is probably at the end of its life. Keep me posted with your results.
Dan
May 24, 2008 | Televison & Video
Picture is dark
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
Feb 14, 2008 | Zenith C27A24T 27" TV
Zenith rear projection TV
it's unual for all 3 crt's to go bad at same time, so have you tried turning up screen(G2) control? If so also there is a cap in the high voltage line that when replaced may lighten up set. Don't have model so I can't go further.
Aug 11, 2007 | Zenith SY2768S TV
The picture is dark
Hi This could be one of three possibilities, one the High Voltage Screen Adjustment is off, Two the Picture Tube is Weak, or Three there is a problem with the Video Drive Amp/Amps, these are things that should be checked or adjusted by a qualified technician, especially the High Voltage Screen Adjustment, hope this helps.
Apr 15, 2007 | Zenith H36F46DT 36" TV
Zenith IQB36B42W TV Logo
21 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
