Question about Frigidaire Washing Machines
LTF2940FS1 problems Will not pump water into machine and control board keeps burning up
2 Suggested Answers
dh1200s
  • 335 Answers
SOURCE: not spinning no draining no 120 volts to the pump
Do you have the FAV6800A/FAV9800A Service Manual?
Did you measure 120VAC to the Drain Pump at the connector on the Drain Pump with power applied to the drain pump or at the Control Board Conn_P8 Pin 4 for Hot to neutral or cabinet ground?
Did you measure this while in Service Mode with the drain pump turned on in Service Mode?
Do you have the schematic of you FAV6800A? It is a FAV6800A correct?
What is the issue with not spinning? If you run a Spin Only cycle will the Spin cycle complete? Are you failing the Spin Cycle with unbalance errors such as DC or UC?
If you truly want to DIY the fix you need to go to a true DIY appliance forum such as this; http://forum.appliancepartspros.com/washer-repair/ I will continue to help you at that forum. This forum is terrible for posting pics and other info.
Rich
Posted on Dec 04, 2010
Hello I have a Fisher and paykel 7.5g smart drive excellence washing machine it doesn't spin and I can smell something burning.thanku Kelly
Has it drained the water out. It will not spin until completely empty. If it is not draining then Iwould say the burning smell is the drain pump overheating. Do not try to run it like that as the drain pump will short out the main control board eventually. Bail the water out by hand, tip the machine back against the wall and check the pump on the front right side of bowl. Replace the pump.
Jan 04, 2017 | Fisher and Paykel Washing Machines
My LG washer stopped mid-load at spin cycle, how can I fix this?
It sounds like a serious fault if there is no power the fuse has gone or some item has burnt out . You will have to arrange for a service engineer to look at it more closely.
Apr 28, 2015 | LG WM-2277HW Front Load Washer
My washing machine will not light up
Generally this problem happens when the drain pump starts to leak under the washing maching. A Fisher Paykel has a main control board under the touch panel that has direct wires running from it to the drain pump. When the drain pump leaks it shorts out the wire connecting it to the control board and blow out the main control. Look under washer and look for the drain pump (Drain pump looks like a fan from the underside.) You will most likely see residue from where the water has been leaking, built up on the pump. If all of the above is true on your machine, replace the pump and control board. Fisher Paykel includes an inline fuse to keep this from happening again.
Mar 30, 2012 | Fisher Paykel EcoSmart GWL15
Fuse burned out on motor control board is the fuse the only problem
The fused burned out not because it is faulty but because a problem occurred, probably a short circuit, which resulted in the high-inrush of current. This burning out of the fuse on the motor controller module usually caused by faulty drain pump motor. Water leaks in the drain pump damages the pump motor winding and results in short circuit which eventually burns out the fuse. The drain pump must be checked first for such condition and replaced if necessary before replacing the fuse or the motor control board for that matter.
Jul 15, 2011 | Fisher and Paykel Washing Machines
Hoshizaki ice machine
The machine will continue to run water all the time while in harvest mode. The control board blew, and just needs to be replaced. Controls boards can fry without any other signs of anything else being bad. Hoshizaki ice machines dont have a over heat relay that shuts it down upon oerheating if it is the control board
Apr 23, 2009 | Refrigerators
Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
Zanussi
E20 = Problems with water drain in wash phase ALARM CODES E20 Is the drain filter clean; Problems during draining phase (Machine tries to drain for 10 min without emptying the tub) Checks to do: E20 Is the drain pump working? Is the value of the pump about 200Ω? (Measure directly the connector by the board, between J2-2 and J2-7) ; If No Change the pump and run again Clean the filter; Is the draining system OK (drain hose and plumbing where machine is connected) Free and check the draining system; Is the pump blocked? Is there any burn mark on the control board; if yes Change the board E90 = Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides, OR replace the blue ribbon cable. The fault could have been caused by oxidized contacts in user interface plugged in the main board. Kind Regards David Marsh
Jun 19, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
