Question about Sunbeam Heritage 2346 Stand Mixer
2349 Stand Mixer - Beaters now hit each other
I cannot put the beaters in any more beacause they hit each other. It looks like the gears skipped a few tangs and line up incorrectly. I can only put one beater in because the they are no longer at offset. Anyone know of a fix or how I can 'retime' the beaters?
  • 2,976 Answers
The beaters can be retimed but, you have to open the mixer. There are 2 gears visible inside the head. Look closely for arrows or dots on the gears. These are the timing marks. Like marks should be placed exactly opposite each other on the work gear. (The spiral shaped gear) Look at the notches where you put the beaters. One will be lined up straight, the other will be at 45 degrees. While you have it opened, you might want to regrease it. Remove the old grease with a stick or small narrow screwdriver. Put vaseline or equivalent in the gear area. Only fill it about half way. If you over fill it, it will leak out when you get it hot from long or heavy use.
Posted on Jan 03, 2009
  • ericwarner May 30, 2011
    this is exactly what I expect to find, once I get inside the puzzle... However I cannot seem to find the magic screw that releases the entire machine... any help is GREATLY appreciated. I have already taken the whole thing apart from the bottom and back and put it all back together, but cannot seem to figure out how to get inside the front end...
Pry up the beater release button. You will find a screw in there and the front will come off. Good luck
Posted on Nov 30, 2011
Replacement parts of Kenmore KSM035 Stand Mixer
I have a set of used beaters, if you are still looking for them.
May 13, 2014 | Kenmore KSM035 Stand Mixer
Got spatula stuck between beaters striped gears
The gears are readily available. Just open the micer and replace them. You will have to pop the buttons out of the front and rear to get to some of the screws. Once you remove the gears, also remove ALL the grease. It has broken pieces in it. Use light lithium grease to refill the gear area HALF FULL. Make sure when you put the gears in, they you line up the marks on them with the motor shaft. One will be straight in line and one will be at a 45 degree angle. This is so the beaters don't hit.
Dec 18, 2012 | Sunbeam 2346 Heritage MixMaster Series...
Beaters are hitting each other and jamming up
One of the beaters had jumped a gear. I understand they are nylon gears. My wife's had the same trouble. I unplugged the mixer, removed the bowl and install the beaters if you can to see where they are touching. They were two cogs off. I grapped the left (red) beater firmly and twisted it to the left. It took a couple tries and turning on the motor (with out beaters) to find the spot where they had skipped. In the end the left beater jumped back one then two teeth and now the beaters aline properly.
This will happen again with heavy dough, etc. now that the teeth are worn in that spot. Use a bread machine for the heaver dough. IMHO
Dec 12, 2012 | Sunbeam 2346 Heritage MixMaster Series...
Need beaters for a black and decker SM100 mixer
I searched for replacement beaters for Blacker & Decker SM-100 type 1 (SM100) electric stand mixer for years. I found the Sunbeam Mixmaster Mixer Replacement Beaters for stand mixers, item 4955, at a large Ace hardware store. They were priced over $16.00, so you may consider buying a new stand mixer. The beaters are the correct length, snap in and grip correctly even though the ends are curved like a half ball rather than flat as the originals. The beaters turns well but I haven't tested them with the bowl because I need to find the turn table that I have in storage. The beater set was design ed to replace parts for Sunbeam stand models 2355-1, 2356-1 and 2360-2.
Jan 18, 2012 | Black & Decker Food Mixers
Wobbling on inside of mixer when beater is rotating
If the beaters are hitting the bottom of the bowl, try adjusting the upper-head stop-screw located near the top of the lower stand--it determines how far the head drops down and therefore, the height of the beaters above the bowl bottom. Hope this helps!
Dec 27, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
The release button to raise the body to take off the beaters will not release. I can't get the bowl out or remove the beaters. Please help.
Put a few drops of cooking oil in the holes the the beaters are inserted inMake sure to unplug the unit. Pushing the button, work the beaters pulling lightly. Good Luck
Aug 11, 2010 | Sunbeam 2370 MixMaster Series Stand Mixer
Missing beaters
try this site for your beaters ..
May 09, 2010 | Bravetti 623-715 Stand Mixer
Mixer beaters clanging together
The beaters might be fixable/replaceable but the bowl not spinning anymore is the more serious of the 2 problems. If this is several years old iit probably is more cost efective/simpler to replace the whole unit.
Good luck Loringh
Nov 08, 2008 | Sunbeam Heritage 2346 Stand Mixer
Sunbeam Heritage 2346 Stand Mixer Logo
783 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
