Question about Samsung SMH9187ST Microwave Oven
Samsung microwave se error - Samsung SMH9187ST Microwave Oven
  • Samsung Master
  • 9,047 Answers
"SE" error means you have a shorted membrane keypad.
On some models, you can peel off and replace the old keypad.
On others, it's best to replace the control panel frame, which contains a new keypad already.
You didn't mention your full model, but if it;s the same as the category in which you posted (SMH9187ST) here is a specific solution:
The simplest way to fix this is a simple DIY solution, to replace the control panel frame assembly, which comes with a new keypad already attached.
It is part number DE94-02001C "assy control panel" and you can order it from the Pros here for about $30 plus shipping.
They may not have it in stock, but if you order it, they can have it in a few days.
You can download the service manual from our site here.
At our Web site , we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock:
Then move your board to the new panel assembly, but be careful since the display is made of glass.
Posted on Oct 26, 2012
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
What does this mean on my Samsung smh9151 microwave oven? -SE-
The SE error indicates a short was detected at the key pad. This could be a problem with the wiring (dirt at a connection) or a bad circuit board. If your microwave is under warranty, contact Samsung.
Since microwaves have high voltage, you may not want to try to fix this yourself. If you do, make sure to be careful. Some have fixed the error after unplugging the microwave. Then disassemble the microwave keypad area. Disconnect the various wires and clean all of the contacts. (Do one wire harness at a time so that you replace them in the right place.) Reassemble and plug in the microwave. Test if the SE error returns. If the error remains, then the control board needs to be replaced. To get the entire keypad and control board, seehttp://www.repairclinic.com/Shop-For-Parts/a6b160i468/Samsung-Microwave-Touchpad-And-Control-Panel-Parts . The board alone is here: http://www.repairclinic.com/Shop-For-Parts/a6b160i324/Samsung-Microwave-Control-Board-Parts .
I hope this helps.
Jan 16, 2016 | Samsung Microwave Ovens
Why does screen say SE
SE = Sensor Error, its reported that it could be components bent over, and touching each other on the PCB behind the keypad.
You need to be a fair bit mechanically savvy to attempt a repair, and remember to Unplug it before you do! :-)
Sep 04, 2014 | Samsung Microwave Ovens
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
Samsung se error keeps coming back
i think your getting to much moisture in your microwave the exhaust fan is to small and can't handle it. once everything dries out you are able to rest it check with samsung.
Dec 13, 2012 | Microwave Ovens
Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
Jun 14, 2012 | Samsung SMH8165W Microwave Oven
Samsung microwave child error/ turnd power off now se appears in window and does nothn when push buttons
SE indicates a short in the keypad membrane, the keypad control board will need to be replaced, a costly venture.
Apr 06, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
Samsung Microwave -SE- Error
how can i fix se error a samsung microwaveSMH9187ST
Mar 30, 2008 | Samsung SMH7178STD Microwave Oven
Samsung SMH9187ST Microwave Oven Logo
120 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
