Question about Sirius SUBX1 Universal Plug and Play Boom Box Boombox
How do i take it apart
I got the handle off and all the screws i can find but still cant get inside it
Drivers door handle replacement....would like to see how to sheet
on inside of door panel r3-6 screws pull out panel pop off be gental dont break tabs that unclip 1 screw holds handle on unclip rod connecting hanle on out side 2 handle on inside pull out put together how u took it apart
Jan 26, 2011 | 2006 Buick LaCrosse
Oven Handle drops off of door
Whatever keeps the handle on is not working. Most oven handles are held on by a screw on each end. It can be tightened from the inside of the oven door. If you don't see the screws, you may have to take the door apart. Buy some longer screws if needed.
Nov 03, 2009 | Kenmore Ovens
Take apart honda accord drivers side door
inside the handle there is ONE screw covered by a piece of plastic. remove the plastic and then remove the screw. pull handle out and disconnect it from the door latch bar. replace in reverse
Sep 17, 2009 | 1997 Honda Accord
Replacing door handle
Take door apart there should only be one screw to get outside cover off handle. when the door is apart there are three screws for the latch and two rods that disconnect (one for the latch and one for the lock)
Jul 11, 2009 | 2000 Kia Sephia
The entrance door handle on my coleman natache pop up camper fell apart. I bought a new one and when I attempted to unscrew the 2 screws that I thought were holding the handle to the door, the screws just...
I also have the same problem. The only way to get into the panel (without completely tearing it apart is to drill out the rivets across the top of the door. The reason the screw is turning is because inside it's held in place with a nut that is turning. You can get to those nuts once the top panel is removed. Can you do me a favor? Where did you find your replacement handle? I've been looking everywhere and it would be SO helpful to be pointed in the right direction!
Jul 09, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
How do i take it off of the door?
:) Hi
I might be able to help but without clarification of what model you have i cant be 100% accurate
MOST door handles have the two screws on the inside of the house/room that fasten the two pieces of the handle that you need to remove.
imagine this d|b as your door handle and door. inbetween them are two square pins that are ontop and below the center of the handle that hold it in position.
once the screws are removed you need to pull the knobs apart. this might be difficult. have one person on each side pull. if this doesnt work see if your able to pop up the face plate on the inside that covers the hole. if you can get a screw driver into the hole and use some leverage.
GL
Note if you can post your model number (try taking a look on the websites of the local hardware stores to visually identify it i can be of definitive assitance
Brad
Apr 04, 2009 | Kwikset Professional Door Lock...
Need to know how to take apart my door
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Mar 26, 2009 | 1992 Geo Storm
Handle on oven door falling
Murray...after a DJ here in NY from the '60's!
First, why is the handle falling off? Is it loose or damaged? Most of these handles are only plastic with holes tapped in. If the holes are damaged and you can't fix them, you will have to replace. Most handles are through bolted in the door. You should be able to access those screws from the inside of the door. If not....
How do take a door apart: First locate any screws in the bottom of the door. Remove them. Open the door and remove screws from the sides and inside of door. Get help supporting the outside of the door and note that it will snap shut when you remove any weight from the door. Caution, most door glass is not well clipped in...it may come loose!!!! You may want to take pictures of the inside of the door once you open it. Once the door is apart, locate any fasteners holding the handle and attempt to tighten them. If not successful, you'll need that new handle. Get an extra set of hands to help with removal and reinstallation of that door skin. You'll need 'em!
Nov 29, 2007 | KitchenAid KESC307 Electric Kitchen Range
Electrolux contour 1100 flexihead. Z1436
You need to unscrew the screw at the back / base of the handle. The whole handle section will need to be slid backwards. Best way is to unscrew the screw on the rear approx 5 turns and then bump the end of the screwdriver. A few more turns then bump the end of the screwdriver again. The whole handle will eventually slide backwards and fall off. Then unscrew the two screws at the front (near switch) and the front switch cover plate will lift up (hinging at the top). This reveals the incoming wires etc.
Jun 18, 2007 | Electrolux Cleaner Lux 6000 Vacuum
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Sirius SUBX1 Universal Plug and Play Boom Box Boombox Logo
54 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
