Question about Averatec 3200 Notebook
I need to replace my hard drive.
I am not sure where it is located on this Averatec Model 3200. I need to remove it to recover data. Can anyone help? I can't find the spec sheet on it.
  • rlarrye Dec 28, 2007
    Thanks to the directions posted under "best solution" I was able to service my daughter-in-laws avertec 3200.
    Be very careful. The screws are tiny, and there is a little white tape to remove. Watch out for the copper colored circuitry strip that runs over the hard drive. Carefully remove the white tape from the strip and the small hard drive.
    I'm now off to get a replacement. Thanks again!
You have to remove the piece of plastic below the keyboard. the screws are on the bottom. becareful not to unplug anything else without notice how to replug the harddrive is behind the usb's. remove rubber spacer and unplug drive and then put everthing back...
Posted on Jul 10, 2007
    Brigadier General:
  • 6,966 Answers
Hi Andei, I'm guessing, but with the laptop turned over and the battery away from, it is on the left side underneath or inline with the optical drive. You may need to remove first the CD drive in order to gain access to the hdd. I also can't find a service manual other than the user's manual (http://www.averatec.com/docs/3200_Series_Manual.pdf). Another possibility is behind the battery placement area. In some laptops I've worked with, hdd is under the keyboard which means you have to pry the kb open. If it doesn't work, you may have to ask a service personnel to do it for you. Hope this works out and pls post again how things turned up. Kind regards
Posted on May 12, 2007
  • 385 Answers
Hi, Turn over the laptop, there should be several compartments: a small one that covers the RAM, one with ventilation that covers where the fan is, there's the battery and finally there is one last compartment (I'm not fully sure but I think this should be where the hard drive is located) Loosen the screws and check under there, if it's not there, please let me know, but according to the manual, it seems like this is the correct location. See the manual from this page: http://www.averatec.com/customercare/manuals.asp Good Luck
How to replace a hard drive in a Averatec 3200? Ken Weakland
After some research, I did locate the user manual for this notebook, the link is below. The manual provides a good deal of information, what it does not tell you is the location of the hard drive. Generally though, the hard drive is located on the bottom of the laptop, under one of the panels secured by screws. Also, generally, the hard drive is enclosed in a cradle with an adapter that connects the hard drive to the system board. To replace, you unplug the existing hard drive, remove the cradle and put the new drive in the cradle the plug it back in.
I hope that this puts you in the right direction to answer your question. Look at the manual, which will show you where many of the other components are located on the bottom of the notebook. This will help you narrow your search.
If you have any other questions about the process, please let me know.
Brian
http://www.trigem.com/us/support/manuals.asp
The link to download the manual to PDF is in the middle of the page.
Dec 24, 2010 | Averatec 3200 Notebook
Need to locate a working identical Maxtor 3200 200GB
Well this is not how I like to answer questions on this forum, but here is a place to start looking for your drive. I hope this helps, there are some listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=+Maxtor+3200&_sacat=See-All-Categories
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Averatec 3200, cant find DVD Rom driver in "My Computer" or "Device Manager" When I put in a CD I can hear the disk spinning but it never loads. I deleated the upper and lower filters and restarted the...
Make sure the BIOS is 'seeing' the drive. Reboot your pc, press F2 as soon as it starts to boot (Or watch your screen and the POST will display which function key to press to enter setup.) If the BIOS is NOT seeing the drive, you may need to a) replace the drivers for the dvd or b) replace the dvd rom itself. (I recommend the drivers first.) Please repost your results and we will continue to monitor your progress.
Good Luck
C2Solutions
Sep 04, 2009 | Averatec 3200 Notebook
I replaced my averatec 3200 hard drive 40gb with 110gb.. does it affect the the whole system? coz sometimes it suddenly shuts down... and one more thing, whenever i run NFS game, the graphics is too...
the hard drive would cause the problem if the hard drive was bad, like if it had bad sectors on it and it couldn't write info to certain parts of the hard drive.
System shutting down on its own could be spyware or a bad hard drive would cause that as well.
As far as graphics are concerned make sure your video drivers are installed cause if there not then the graphics wouldn't be as good. Make sure you get the latest drivers from the averatec website.
If your worried about the hard drive, put in another one but make sure its a new one so you know you have the best chance of it working properly.
Averatec serie 3200 crashed new hard drive need drivers
the same way you typed it here try google it gives you the drivers then you install.
Jul 04, 2009 | Averatec 3200 Notebook
I have an averatec 3200 laptop.no display
Yes..most probably its HDD. Remove the hrddisk and try booting. If it displays, no HDD.then the prob lies with HDD.
Jun 07, 2009 | Averatec 3200 Notebook
Averatec 3200 lap top has a virus
The recovery disc will do the deleting for you. Make sure you've got all of your data off before running it.
Post back if you have issues during or after the restore process.
Mar 02, 2009 | Averatec 3200 Notebook
Compter won't reoot
Try booting with using the Last Known Good Configuration option.
See if you can get into windows that way.
Let me know if that doesn't work and we talk about salvaging you data.
Regards
Dec 20, 2008 | Averatec 3200 Notebook
Change hard drive
You will have to disassemble the laptop a bit to swap hard drives. Check this link: http://www.flickr.com/photos/dnhoshor/sets/72157602004333279/show/
it shows a photo disassembly that was made to repair the power jack bu you will see the hard drive in image # 10
hope this helps
Apr 23, 2008 | Averatec 3200 Notebook
Buying a hard drive for the Averatec 3200 Series
I have a tip. Don't forget to set up the drive as master or slave (depending on what you want the drive for). I personally have forgotten to double check this on numerous occasions (its always the simplest thing you overlook with everything) only relizing when I have the case screwed back on and am trying to boot the drive up.
Aug 11, 2007 | Averatec 3200 Notebook
Averatec 3200 Notebook Logo
2,020 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
