My router is producing a weak singal {2 bars} so I can not hook up to the internet.
Tried rotating the router 90degrees and checking connections and resetting and powering it down.
  • lawrence m rose Oct 27, 2012
    Thanks everyone for the advice. I did not have a bad router connection even though it showed only 2 bars. A friend tried resetting the computer back to a date before the problem existed to clear fix it.
  • 32,281 Answers
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Posted on Oct 25, 2012
5 Suggested Answers
Democritus
  • 120 Answers
SOURCE: lost internet connection to my 2nd wireless p.c
Suggestion: Move your router. Your PC 3 appears to be in a 'dead zone' so to speak.
Posted on Nov 21, 2008
BelgianAlien
  • 50 Answers
SOURCE: No access to the internet
When you say you did a reset on the router, did you unplug it and plug it back in after a while, or did you do a reset to factory settings?
If you have access to the settings of your router, check to make sure the firewall in your router is not set to block all connections. Also, make sure your IP filters are not enabled. This could cause ANY computer connected to this router to not be allowed an internet connection. Depending on where and when you bough this router, it might have "ZoneAlarm" settings as well. Unless you have a full version of ZoneAlarm (not the free version), make sure ZoneAlarm Pro is disabled in the router.
Please keep us posted.
If this information helped you solve your problem, please rate this solution.
Thanks!
Posted on Mar 19, 2009
  • 10406 Answers
SOURCE: d link dir 615. Weak signal, router is put on main
Try turning the router 90 degrees, and measure the strength.
Turn it another 90 degrees, and measure again.
Repeat.
Repeat.
Move to a house with wood cross-beams, instead of metal cross-beams inside the first-floor ceiling.
Rotate the upstairs computer 90 degrees, and measure again.
Buy a "Wireless N" router, for greater signal strength.
Posted on Oct 09, 2009
  • 1738 Answers
SOURCE: lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
Posted on Oct 27, 2009
My WRT54G2V1 is now producing a poor or weak signal to the 20nd computer. I have reset it and poeered it down a couple times
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 24, 2012 | Linksys Computers & Internet
I can only get a weak signal (2 bars0 from the box iv (in my "study",next to my computer) to my samsung internet access smart tv ( in my lounge). O2 has changed the box ii for a box iv,but the...
di you try to place it in other place of your house. check first if you buy the product if it is appropriate in your location..try to ask technical assistance to the internet provider.
Sep 17, 2011 | Computers & Internet
I am trying to log on with an ipod. The router is an actiontec gt704wg and I am asked to join the network TK096. I have tried the password "password" but no luck. ???
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 26, 2011 | Actiontec GT704WG Wireless Router...
Wnt let me play any games. tried eveything even buying and dwn loading ot the playstation site
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
Modem light keeps blinking Have tried resetting. Restoring to default settings. If I hook the computer directly to the time warner modem I can acces the internet fine. Thanks
If the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
How to configure the router for Time Warner?
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
3.Under Internet Settings, change the connection type as Dynamic.
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 10 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
For any advanced help, revert asap!
Thanks and regards,
Arvind
Jul 04, 2010 | Belkin F5D8236-4 Router
Internet service on only 1 pc
Yes, the 2nd PC will need an RJ 45 cable ( straight through ) not a crossover.
This cable is connected to the port connector in the router on the back numbered 1-2-3-4. That is if it is a 4 port router.
You can select either one preferably the number 2 port will do.
Then the PC should detect the connections and you will be on. automatically.
1. Check the network in the task bar on the bottom right of you screen for the 2nd PC and see if you have a connection.
If this is Windows XP you will see an Icon with to monitors showing . Right click to see the connectivity.
Mar 18, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My ISP is Embarqmail.com (not listed) so I checked
If it is Belkin Then You will need to do the following steps
Step 1 : Connect The Router - Computer ( Wired ) And make sure the modem is not connected to the router at this time
Step 2 : Open RSP By typing 192.168.2.1 on the address bar of internet explorer
Step 3 : On the left hand side click LAN Settings
Step 4 : Leave the password blank and click submit
Step 5 : Change the IP Address into 192.168.3.1
Step 6 : Click Apply changes
Step 7 : Open RSP By typing 192.168.3.1 on the address bar of internet explorer
Step 8 : On the left side click Connection type under Internet WAN
Step 9 : Leave the Password Blank And Click Submit
Step 10 : Choose the Connection type As ( Make sure you get the Connection type right , Contact your ISP About this ) Dynamic \
Step 11 : Click Apply Changes
Step 12 : Connect Modem - Router
Check the Internet Status
Mostly this will work
Dec 29, 2009 | Belkin Computers & Internet
Lost internet connection to my 2nd wireless p.c
Nov 19, 2008 | Computers & Internet
2 wire router and Comcast
Cable from modem gets inserted into router port named WAN/Internet
from router you should have a cable going into back computer ethernet port.
once inserted, input router IP address into an address bar (IE or My Computer) eg. 192.168.1.1 --- to find out what your router I is:
Start > Run > cmd > ipconfig /all --- router ip would be listed as Default Gateway or DHCP server
Once logged into router, go to Properties page of router config and perform a Release and Renew of router's ip
Jun 30, 2008 | 2wire (1000-400108-001) Router
Router Troubles
1. Try turning off your computer,then your router and your modem
2. Then turn on first your modem, your router and your computer
3. If no internet connection still, try reseting the router for 10seconds.
4. Make sure that the local area connection of your computer is set to obtain
5. If still no internet. Access configuration page of your router by typing the gateway of router router in your address bar
> you can check your gateway by typing ipconfig on your command prompt. It is your DG there. (Usually 192.168.1.1 or 192.168.0.1)
6. Make sure that configuration type or connection type is set to DHCP. Then clone your computers mac address.
7. Check your status page.You should have ip address, default gateway and DNS there.
Jan 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
