Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlain 1/2hp won't open/close and learn LED flashes 5 times
My Chamerlain 1/2hp opener won't open or close, and the motor hums for a few seconds when I try to activate it. It actually sounds as if the motor tries to move in one direction then the other before it stops. Also, the LED light next to the transmitter button flashes 5 times, pauses for three seconds, then repeats the 5-flash cycle. Any ideas?
  • 1 more comment
  • hankonthego Jan 03, 2009
    I have same problem and my traveller is all the way against the bolt...
    scott
  • dbaum25 Jan 04, 2009
    We are having the same exact problem w/ the same device however our traveler is not jammed against the bolt...motor sounds but no movement at all - tried unplugging operator for 2 minutes with no solution...
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    Where is the traveler? Is it all the way to the powerhead jammed against the bolt?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
The gear needs to be changed kit #41c4220a. Be sure to change the bottom bushing on the motor mount.
Posted on Jan 04, 2009
Do you have to pull the gas tank out to check e\for fuel pump operatons
no remove fuel cap put your ear close to open filler neck have some one turn on key you should hear a humming sound if not bump key then listen again it will only hum for a few seconds
Jan 21, 2013 | Cars & Trucks
Disc tray will not open?
There could be a disc jammed in the tray. The humming sound is the tray open/close motor trying to work
Jan 16, 2013 | Bose Av3-2-1 Series Ii Media Center...
Whirlpool wtw5700sw0 won't spin and motor hums
Please check the motor capacitor, use a capacitor in parallel to confirm. check the motor spindle and paddle for free run., Please check this link;
http://www.espares.co.uk/advice/washing-machines/a/7/1379/how-to-replace-the-carbon-brushes-on-a-washin.html
Mar 14, 2012 | Whirlpool WTW5700S
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
The garage door hums for a few seconds and then stops, the door won't go up or down.
Make sure the trolley isn't jammed against the bolt just in front of the motor.
Oct 29, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door hmmmms but will not open or close. How can I fix this?
Could be the start capacitor is bad. When this happens the motor will not start but just hums for a few seconds. Could also be that the door is open and jammed against the bolt just in front of the motor unit. Is the door open or closed?
Jul 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor wont run on craftsman opener
You need to remove the cover and look at the drive gear. It is probably stripped. I really recommend a technician to repair your door.
May 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote will not operate garage door opener from outside garage
Will the remotes work in the garage? If yes but not outside with the door closed you might have radio interferace with your remotes. You might have to chage to a your reciever and remotes to a different brand (frequency). Sometimes it is less trouble to change out the operator. Chamerlain changed frequency from 390 (old) to 315 (new).
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
375 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
