Question about Microwave Ovens
My microwave turntable is scrubing the finish off the surface underneath the wheels of the turn table. this has exposed bare metal. Is it safe to use? Weare currently useing it with the turn table turned off.
  • wwclg Jan 07, 2009
    Thanks so much. YOU
    Thanks so much. You solved my problem and saved me some money also.
  • Microwave Ovens Master
  • 9,098 Answers
The floor will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
I would then leave the door open to let it dry untouched overnight.
You didn't mention your oven's brand or model, but it may be that the wheels on the turntable support are worn or there may grease built up in the axles.
Or you may need a new turntable support.
If you need to order a new one, please reply back with your brand and model number so we can help point you to the proper distributor.
Posted on Jan 03, 2009
  • William Miller
    William Miller Jan 08, 2009
    So is that a "FixYa"?
    We're
GE microwave JVM1631 turn table not working. How to fix it?
The motor underneath the turntable may have failed. Removal of the access cover will expose the motor for continuity checking
Aug 17, 2013 | GE JVM1631 Microwave Oven
Paint inside microwave is chipped and blistered. How do you fix it?
HI,
If you are able to spent money for a new Microwave then go for a new one.
If you are interested to repair and reuse the existing Microwave then keep on thing in mind, if you paint it then also it will not lasts for a long time as the metal underneath is rusted.
Ajin
Jul 14, 2012 | GE Microwave Ovens
My oven sparks from the metal plate on the side.
Check to see if there is any rust or cracks in the coating that came from the factory. Some microwaves use metal underneath an epoxy type coating and if it is exposed, it can cause an arc from the microwave generator. If there are any defects in the surface, it can be sanded down and you can purchase a can of interior microwave paint and put a coat of paint over the defective area. Also look for any exposed metal in the area of the sparks, there should no metal exsposed anywhere, if it is, cover it with the paint. hope this helps.
Feb 13, 2011 | GE Profile Spacemaker Over-the-Range...
I have LG MS-3444DPS Intellowave Microwave oven. Turntable has had intermittent high pitch squeal and also thumping noise as turn table turns. Turn table has also been very jerky since new. What is the fix...
If you were to take the turntable coaster out and wash it in hot washing up water paying attention to the wheel surfaces, I think that will fix your problem as I suspect the wheels are uneven with deposits stuck to at least one.
Hope this helps.
Nov 27, 2010 | LG Microwave Ovens
Microwave turntable guide
it could cause the magtron to arc...becaus the exsposed metal...you can purchase the paint for the inside color of microwave...sand around area..wipe out,,,unplug microwave first....leave door open ,spray it ,let stand couple of hours or 1 day...hope this helps...michael doctorr airr appl.repair 843-384-8474..call if need assistance..good luck
Mar 26, 2010 | GE JES1851 Microwave Oven
Sparks coming from underneath turntable.
check for black spot on support for turn table and floor of unit, sand them back to the metal serface and paint if cavity is not stainless steel, if turn table is not turning replace the motor as this could cause this issue as well.
Feb 04, 2010 | GE Advantium 120 Convection/Microwave Oven
Flash in oven
The flash is usually caused by metal either being placed inside of micro or the interior surface might have chipped enamel exposing the metal underneath. Make sure no metal materials are placed inside while using and that the interior surface is in good condition.
Dec 08, 2009 | DCS MO-24-SS Microwave Oven
COATING ON INSIDE OF MICROWAVE HAS STARTED TO COME OFF, EXPOSING UNDERNEATH SURFACE, IS IT STILL SAFE TO USE AND EAT FOOD COOKED IN IT?
Nothing special in there. As long as the paint is not flaking into the food you are ok, Be aware that bare metal could begin to arc. There is special microwave paint available but it will not match and look bad unless you redo the entire interior.
Eric
Sep 15, 2009 | Panasonic NN-T990SA Microwave Oven
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Carosel quit working
There is a motor underneath the turntable. Very cheap to buy. Turn it upside down and start figuring how to get at the motor. I have seen microwave ovens where you have to bend out a piece that is a pre-stamped opening to get at the motor. Usually, it is just "take out screws" until you get enough sheet metal out of the way.
Jul 23, 2008 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
