Question about Konica Minolta Minolta CF 3102 Laser Printer Toner Cartridges
Konica minolta printer cf2002 error c0511
Fuser note came on to change, put new fuser in work for a few pages then came up with error C0511, changed fuser with another printer fuser works in both printers but printer still has error C0511
SOURCE: Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
Posted on May 27, 2008
  • 60 Answers
SOURCE: Konica Minolta C450 User Manual
http://kmbs.konicaminolta.us/content/products/models/bizhubC450.html?info=Manuals
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
  • 3 Answers
SOURCE: Status monitor for Konica Minolta 2400w
The status software does not run when the printer is shared. Whenever I have a problem I have to unshare the printer then run the status and it will show up. I then resolve the problem then turn the share back on.
Pain I now but it works
Posted on Dec 17, 2008
  • 6 Answers
SOURCE: printer is offline
go to Start... click Run .... type services.msc and find print spooler right click stop and click start again
Posted on Jul 16, 2009
How can I fix error code c0511 on a Di2010?
by throwing it in the ocean and upgrading to a model that's not older then me xD
Jul 01, 2014 | Konica Minolta bizhub Office Equipment &...
Konica di3510 c0511
To reset you will turn on the machine then take a paper clip end gentle push one end into the tiny hole on the right side of the operational panel the screen will change you are waiting for a small dot to appear on the left side of the screen in middle when that dot appears touch the 3 button. the machine will continue to show the code but now go to Utility/Counter button touch it you will see a new setting called maintenance mode touch it touch trouble reset let the machine go though it routine you will see the dot again let it go. Machine should go Ready To Copy if the code comes back get a tech out to look at it you are messing with the fuser the hot part resetting over and over mite catch on fire (Would ruin a perfect good day:) Hope this helps
Jan 16, 2014 | Minolta Di3010 Copier
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
It appear an C0511 code error on the display, I want to now how it mean, what's the problem hapen exactly in my machine (KONICA MINOLTA Di3510)
It means you have a low temperature in your fuser. This could be due to a faulty fuser or could just need settings adjusted to regulate the fuser temperature
May 02, 2011 | Office Equipment & Supplies
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Konica Minolta CF-910 which has an error code C0511. How can I fix this? Someone said something about a reset button but I need its exact location.
this is an error with the fuser unit temp there is a reset switch it is under by the interlock swith you should be able to reset it if it keeps coming up you will need to replace parts on the fuser unit it is an issue with low temp
Jan 20, 2011 | Konica Minolta DiALTA CF910 Copier
Error code C0511
This is an issue with the fuser unit replace the fuser unit assembly you can replace parts with in the fuser unit but only by a trained technician
Jan 11, 2011 | Konica Minolta DiALTA Di200 Copier
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
Apr 16, 2009 | Konica Minolta bizhub 180 All-In-One...
Konica Minolta Minolta CF 3102 Laser Printer Toner Cartridges Logo
47 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
