Question about Amana 3.2 cu. ft. Top-Load Washer
For amana top loading washing machine, how do you get to tub seal
Need information how to get to tub seal on amana washing machine
  • reggie h Jan 26, 2009
    how do i get the adgitater out so i can replace the tub seal
  • 65 Answers
AGITATORS ON THESE MACHINES NORMALLY HAVE A BOLT THROUGH THE MIDDLE OF THE AGITATOR. PULL OFF THE SOFTNER DISPENSER AND LOOK INSIDE FOR A 1/2 INCH HEAD BOLT OR IT MAY JUST PUSH ON. AS FOR THE INFORMATION AS TO HOW TO DO IT, THE SEAL KIT COMES WITH SOME GOOD INSTRUCTIONS HOWEVER THE TROUBLE IS SOME OF THE SPECIAL TOOLS NEEDED TO PROPERLY REMOVE AND TIGHTEN SOME OF THE PARTS. ASK YOUR PART SUPPLIER ABOUT WHAT TOOLS YOU NEED TO CHANGE IT OUT.
Posted on Jan 27, 2009
    Sergeant:
  • 311 Answers
Hi potterstreas,any amana a couple years old is an maytay.they have had lots of problems with their thriple lip seal[water ,tub seal]you can order and parts on line by model# use our links if you like or google your brand/modelor sears online.have fun.God bless
Posted on Jan 02, 2009
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
3.1 Amana super Cap Top Load washer NTW4880YQ water levels
You need to check the water pressure hose between the tub and console for blockage. Be sure to blow it out good. If this does not clear up the problem, replace the pressure sensor. Here is the part to order.
Nov 05, 2012 | Amana 3.2 cu. ft. Top-Load Washer
Leaks while tub is filling.
could be any number of things: water inlet to tub leaking and running down outside tub,tub seal on top of transmission,pump leaking,bad hose washer remove top and front cover,then plug-in and let it start to fill you should be able to see your leak easier that way be careful when plugged-in
Aug 02, 2009 | Amana NAV2335A Top Load Washer
Amana top load washer fills with water and will not stop filling
Hi...
You need to check this
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
Good luck !!!
Regards
PCmania
Jul 07, 2009 | Amana Washing Machines
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Brown stains from wash machine
Hi!!! Your tub inner seal is worn off its a seal which protects the inner tub fron the transmission..Need a new tub seal..Good luckk..
Jan 03, 2009 | Washing Machines
Loud and leaky
Tub bearing replacement on ANY Amana (Maytag) can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Maytag washers require specialized tools for removing certain components of the machine.
May 28, 2008 | Amana NAV5800A Top Load Washer
Leaking water from bottom of tub
this is bad it needs a center seal/bearing kit this is qite common in the Amana / Maytag line.they are kinda hard to install you may need a service tech to do this for you the kit runs around 80.00 dollars and has instructions. if you need more help you can email me at familyappliancerepair@yahoo.com
Dec 06, 2007 | Amana ALW480DA Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
226 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
